Amp for DIY sub - Page 3 - Home Theater Forum and Systems - HomeTheaterShack.com
post #21 of 30 Old 02-23-07, 07:11 AM
Bob in St. Louis's Avatar
Bob
Re: Amp for DIY sub
Brian Bunge wrote: View Post
If you are using the sub with a fairly recent DD or DTS surround sound receiver then you don't need a crossover. It's built into the receiver.
....Unless you're using a receiver that "flys in the face of conventional thinking" because it has TWO XO points that nobody you've talked too has a clue how to set it up...
Bob
Bob in St. Louis is offline
post #22 of 30 Old 02-24-07, 05:47 AM
Chrisbee
Re: Amp for DIY sub
JorgenMan wrote: View Post
A friend of mine has one sitting right above his TV and says it isn't a problem. I've only been over to his house once, but I didn't notice the fans at all.
EDIT: The Nady fans are louder, not quieter, than the Behringer fans. You can, however, replace the Nady fans with quiet PC fans (Panaflo, for example). I think the common fix for the Behringer is to put a resistor in series with the fan to slow it down, because the fans aren't a standard size.
The Behringer fan is 24 Volts and is standard PC (home computer) size.
My replacement 24 V fan (Papst 8414 NGL) is totally silent as regards air movement but can be heard ticking from close up.
The original Behringer fan was so noisy I could hear it 12 feet away as a waterfall sound through the cones of my IB from where it was sitting in the rear enclosure.
On my IB the lower speed fan does not cause any overheating whatsoever. I monitored the heatsink for a while with a digital thermometer. The temperature only rose above ambient by a couple of degrees F even after an hour of Metallica @ 100dB.
Chrisbee is offline
post #23 of 30 Old 02-24-07, 09:47 PM
JorgenMan's Avatar
Aaron
Re: Amp for DIY sub
Chrisbee wrote: View Post
Ah, my mistake. I knew there was something semi-unconventional about it. Just for clarification, what is the size (there are a couple standard PC fan sizes)?
JorgenMan is offline
post #24 of 30 Old 02-25-07, 07:44 PM Thread Starter
tom
Re: Amp for DIY sub
Thanks for all the suggestions. I haven't been on here lately, but I ended up getting the BASH amp sent to me. I talked to PE and they said I wouldn't get the amp, then got an email the next day saying it had shipped.
So, I have done the capacitor replacement for a highpass around 15Hz. The caps were not easy to access, but the amp is working great.
letzleta is offline
post #25 of 30 Old 02-25-07, 08:19 PM
BoomieMCT's Avatar
Boom
Re: Amp for DIY sub
letzleta wrote: View Post
You replaced the caps? I thought changing the R17 and R18 resistors in the pre-amp were all that was needed. What exactly did you do? I have two of these I did the resistor change on but haven't yet finished the enclosures for them.
BoomieMCT is offline
post #26 of 30 Old 02-26-07, 10:45 AM Thread Starter
tom
Re: Amp for DIY sub
Sorry Boomie, I mistyped... I keep mixing up the word capacitor and resistor.
I replaced the resistors, that is all I did. I also finished and painted the box for it, however, I may repaint it when I finish the sub because the edges didn't turn out as well as I would have liked.
letzleta is offline
post #27 of 30 Old 02-26-07, 10:48 AM
BoomieMCT's Avatar
Boom
Re: Amp for DIY sub
Whew! You gave me a bit o' pucker there for a moment.
post #28 of 30 Old 02-26-07, 11:28 AM Thread Starter
tom
Re: Amp for DIY sub
Also, as soon as I can get the images of the amp/box uploaded I will post them up here. The pictures don't do the box justice, but you can see it anyway.
letzleta is offline
post #29 of 30 Old 02-26-07, 11:37 AM Thread Starter
tom
Re: Amp for DIY sub
Ok, here is a link to the photos in the galery:
http://www.hometheatershack.com/phot...00&ppuser=5557
The side shot of the amp box looks bad, but in person it doesn't look like that. The flash on the camera does some funky things.
letzleta is offline
post #30 of 30 Old 03-07-07, 04:36 PM
Jerry
Re: Amp for DIY sub
I have two Nady XA-900 amps. Replacing the fans is a snap. I cannot hear the fans at all and the amp runs cool even during testing. Stable as can be into two ohms running parallel mode two channels, one channel per driver.
Some info for both the Behringer and the Nady Here
htnut12 is offline
amp , diy
