Speaker cables, large amps - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 9 Old 10-31-10, 10:35 AM Thread Starter
Bugster's Avatar
Bugster
Hi guys!
What gauge speaker cables are you useing with the large PA type amps?
I will soon, hopefully, finish my two maelstrom builds, and need to buy some cables, both internal and external.
My amp is a Behringer EP4000.
Thanks
Bugster is offline
post #2 of 9 Old 10-31-10, 10:50 AM
Generic
Inactive
Posts: n/a
Re: Speaker cables, large amps
I think its still dependent on the distance of speaker wire you need. I think my Crown came with a speaker wire guide, but I didn't actually change my speaker wire. Its either 14 or 16 gage. Its only run a few feet too.
If your going to actually push your pro-amp, you might need to upgrade, but I'm probably not even pushing mine 25%, I just wanted a clean sounding amp.
post #3 of 9 Old 10-31-10, 11:15 AM
Ricci's Avatar
Josh
12ga is fine unless you have a really long run over 50ft. You might want to use 10ga at that point. Just use either 2 or you can use 4 conductor 12ga speakon cables.
Ricci is offline
post #4 of 9 Old 10-31-10, 12:27 PM Thread Starter
Bugster's Avatar
Bugster
Ok, they only need to be about 3-3,5meters.
I asumed I would need 9 or 10 gauge. I might do that annyway, I like the cables to be on the beefy side.
Thank you!
Bugster is offline
post #5 of 9 Old 10-31-10, 02:31 PM
bambino's Avatar
bambino
With that distance and with the wire charts i have seen i wouldn't fear using 12awg. That should be more then sufficiant.
bambino is offline
post #6 of 9 Old 11-01-10, 07:50 AM
tcarcio's Avatar
TC
I go to Lowe's and buy 12g lamp chord for all my pro amps. I have runs from 5' to 25' and it has never failed me....
tcarcio is offline
post #7 of 9 Old 11-01-10, 10:40 AM
usrsld
Here's a site with plenty of good information on speaker wire including a distance chart...
http://www.roger-russell.com/wire/wire.htm
usrsld is offline
post #8 of 9 Old 11-01-10, 05:11 PM
bambino's Avatar
bambino
tcarcio wrote: View Post
I like that you are not afraid to be one that does that tcarcio, i have read many reports that folks with "golden ears" cannot tell a differance in sound between that and say Nordost or some other mega buck brand.
bambino is offline
post #9 of 9 Old 11-04-10, 01:46 AM
I use 2.5mm˛ (~13 AWG) for just about everything.
Lucky7! is offline
amps , cables , large , speaker
