Quieter Fan Mod for Behringer EP2500 - Page 6 - Home Theater Forum and Systems - HomeTheaterShack.com
post #51 of 206 Old 09-03-07, 02:44 AM
looneybomber's Avatar
Looney
Re: Quieter fan mod for Behringer EP2500
kesa32 wrote: View Post
Hi, l've got a electronics mate installing a thermal switch in my ep2500 tommorow to turn the fan on&off .......it is adjustable too , so we'll start with 35 degrees celcius and go from there, if this does'nt do what l want l'll hunt up an even quiter fan as the one l got isnt quite enough for me.
l'll get some pics happening of the instal too
Ken
Yeah, get some pics if you can. What I ended up using was two of these fans.
http://www.enermaxusa.com/catalog/pr...roducts_id=102
They flow the same amount of air as the one from Newerk.com, but are only 14db compared to the 24v fan's 21db.
I'm thinking of replacing the OEM fan, but using it as an exhaust instead of an intake, and then a second (wired in series for that 24v rating) at the front of the heat sink to blow fresh air through it from the front of the amp. 20bucks is a fair chunk of change to spend on something like this though.
*edit* I've been a member for 1 year and this was my first post. Huh. Oh well...
*edit #2*
I have both fans installed...sorta. I was unable to place the second fan infront of the heatsink without grinding away part of the amps front plate. I still have yet to find a good place to put the second fan. I may place it with my exhaust fan in the back inside that shrowd. We'll see if that works. It is very quiet though I will say!
*edit #3*
Well, I have both fans piggy backed in the existing fan location, but both blow out instead of in. The air flow is lower than with the original fan, but even playing for 20-30mins with the clip lights blinking occasionally, the amp never gets hot. The air coming out is warm, but it doesn't get near as hot as my receiver does!
looneybomber is offline
post #52 of 206 Old 09-03-07, 06:30 AM
Dan
Send a message via MSN to Danny
If you're doing that make sure the air still flows in the same direction as before, some heatsinks work best with a positive negative pressure differential.
Danny is offline
post #53 of 206 Old 09-03-07, 10:15 PM
Steve
just do the single fan and it will be fine. On a 90 dregree day i watched Return of the king and the amp never kicked out or had any problems at all, even though it was quite hot.
it will be fine.
ccdoggy is offline
post #54 of 206 Old 11-01-07, 04:48 AM
Egil
After several months with that awful loud noise from my EP2500 I finally got a new fan in the mail! A Papst 8414 NGML (19dB). I just cut the wire on the old one, and used some electrical tape to connect the wires on the new fan. The result? Around 62dB right next to the EP2500.. but my listening position(s) is 4 meters away from the EP2500 - so you don't notice any noise while listening to music or watching movies. Great mod
Egil is offline
post #55 of 206 Old 11-01-07, 08:46 AM
toecheese
Is there a definitive list of part numbers to check? The Newark one doesn't list the noise level for that model.
Edit: the NMB P/N is the same as the 21dB Panaflow. Guess they're the same company.
toecheese is offline
post #56 of 206 Old 11-01-07, 06:24 PM
Warner
Just finished the fan mod. At least on my amp it was easier to cut the wires near the fan and solder the new fan wires to them. All you have to do is cut the black shield back and slit between the red and black to separate them.
Trying to use an exacto with that much hot glue would have taken a lot longer.
warnerwh is offline
post #57 of 206 Old 11-01-07, 08:40 PM
Josuah
Only took me about 30 seconds to cut through the glue and disconnect it. I'm using an Vastech Alien I.
Josuah is offline
post #58 of 206 Old 11-04-07, 08:13 PM
Warner
Josuah wrote: View Post
Well I guess you're more patient than I am.
warnerwh is offline
post #59 of 206 Old 11-30-07, 10:47 AM
toecheese
I just did the mod using a fan bought from Newark. Awesome. Verrrrry quiet now. Be careful about that fan shroud because it isn't correct in Chris' original photos, but someone's follow is correct.
post #60 of 206 Old 11-30-07, 12:16 PM Thread Starter
Chrisbee
I'm glad somebody else has noticed the "deliberate" mistake.
Chrisbee is offline
behringer , ep2500 , fan , mod , quieter
