Quieter Fan Mod for Behringer EP2500 - Page 9 - Home Theater Forum and Systems - HomeTheaterShack.com
post #81 of 206 Old 09-04-08, 10:03 PM
Re: Quieter fan mod for Behringer EP2500
You know... when I was looking at those coolerguys fans, I was not even paying attention that a 24v was required. I have not looked, but they may have one, but the Newark should work just fine.
Sonnie is offline
post #82 of 206 Old 09-04-08, 10:08 PM
Matt
Some people do use 12v pc fans, but they change resistors or something...beyond my knowledge, lol.
E-A-G-L-E-S is offline
post #83 of 206 Old 09-09-08, 04:38 PM
Matt
My newark fan didn't come with a clip on the end of the wires, can I use the factory clip after removing the old fan?
post #84 of 206 Old 09-09-08, 04:51 PM
kouack
of course you can
kouack is offline
post #85 of 206 Old 09-09-08, 05:20 PM
Matt
Thaks, do you just splice into the existing wires just before the plug and then solder the connections?
post #86 of 206 Old 09-09-08, 06:08 PM
Matt
Wow, what a differnce!
post #87 of 206 Old 09-12-08, 02:24 AM
Chris
E-A-G-L-E-S wrote: View Post
So is the newark the most commonly used 24v?
Seems easier to use a 24v than switch to a 12v.
These suckers are fairly loud, lol.
The Panaflo model is most commonly recommended, because after a long series of attempts at resistor mods and fan replacement, the Panaflo was found to be the lowest noise option in a certain extended length thread concerning Ep2500 fan options, and by a significant margin, based on my imperfect memory.
-Chris
WmAx is offline
post #88 of 206 Old 10-06-08, 08:50 AM
skarr
Could you try two 12VDC fans in series (along with some series resistance to reduce the fan speed for quieter operation)??
SubMan is offline
post #89 of 206 Old 10-06-08, 11:12 PM
CZ Eddie
Don't mess around with 12v or series or anything else odd. Just do it right the first time.
What I quoted below is all you need. It is absolutely innaudible from three feet away in an absolutely silent room.
Get your refridgerator going or the A/C and you can't even hear this fan with your head right next to it.
CZ Eddie wrote: View Post
Thanks to this thread, I picked up the 24v FBA08A24L1A from arrow dot com for about $19 including second day air (I was in a rush). I have less than ten posts here, so I can't post the direct link to arrow.
Installing the fan was one of the easier things I've done lately.
Results are very good. The EP2500 is not what I would consider "silent". But the fan is inaudible from more than a few feet away, or at my sitting distance. I can only hear it when I walk right past it.
I would do this mod again. And it's safer than going with a 12v fan.
CZ Eddie is offline
post #90 of 206 Old 10-11-08, 08:24 PM
expresso
hi - i just changed out my fan from a QSC GX5 amp - i put in the panaflow model 24 volt - low speed -
works excellent in terms of noise - i cant hear it at all now - almost wonder if its working -- i did check it before i closed the amp - it worked - i just spliced the wires because i didnt have and cant find the 2 pin connector -
i have a guestion if anyone would know - does this fan spin the same speed all the time ? or does it speed up as more volts are sent to it when the amp gets hotter ?
i hope this fan is enough to keep it from shutting down or doing any damage - i am using it for HT use and music - i do listen to music loud at times - but not for that long - has anyone had issues when using this low speed fan ?
thanks
expresso is offline
behringer , ep2500 , fan , mod , quieter
