Behringer iNUKE Class-D Amps: NU1000/NU1000DSP, NU3000/NU3000DSP, NU6000/NU6000DSP, NU4-6000 - Page 42 - Home Theater Forum and Systems - HomeTheaterShack.com
post #411 of 425 Old 10-31-14, 08:02 PM
Re: Behringer iNUKE Class-D Amps: NU1000/NU1000DSP, NU3000/NU3000DSP, NU6000/NU6000DSP, NU4-6000
I just bought a NU6000DSP for my subwoofers. I have it all setup and when I have the power triggered through a smart strip, I am getting a loud turn-off pop on channel B only. Even with the input cables unplugged, channel B pops. If I use the power button I don't seem to have this problem.
I'm curious if anyone else has a channel B power-off pop when unplugging. Perhaps mine is defective? (Unplugging is no different that using a smart strip or power sequencer).
I do not want to have to turn this on/off manually every time I use my system. Suggestions?
Dreamliner is offline
post #412 of 425 Old 11-04-14, 11:13 AM
lsiberian's Avatar
lsiberian
Just use the power button?
lsiberian is offline
post #413 of 425 Old 11-04-14, 01:19 PM
Dreamliner wrote: View Post
lsiberian wrote: View Post
Any other ideas?
I think I saw a thread on a forum somewhere with people wiring up relays to the power button and getting turning it into a 1/8 trigger from the receiver. I think I'll end up having to go that route.
post #414 of 425 Old 11-04-14, 06:42 PM
Belkin PureAV Home Theater Power Console -Black https://www.amazon.com/dp/B001541R5W..._Lnwwub1GPPGEN
Im using this without problems
There is a remote connector, so, when the avr is turned on, the switched outlets are turned on too.
alfa-74 is offline
post #415 of 425 Old 11-04-14, 06:48 PM
alfa-74 wrote: View Post
What model amp do you have? When I use a smart strip to kill power it pops. I've read it may just be the DSP models.
post #416 of 425 Old 11-05-14, 12:25 AM
I have the iNuke 1000 plain, no DSP (I have a miniDSP).
I just realized that you have an NU6000, so you need a lot more amperes, so, my guess is that this belkin will not work for you, although is rated to 15 amp
When I was investigating on how to turn on the iNuke with a remote I saw this:
http://www.amazon.com/Furman-MP-20Q-...=furman+outlet
This may work for you.
Regarding your pops, you may need to delay the on/off sequence for your equipment. something that I learnt is that you need to turn on first the source (AVR for example) and later, following the signal chain, the amp at the end. And the sequence for turn off is backwards, first turn off the amp and at the end the AVR.
I have this sequence on my equipment and I don't have any pop sound.
Hope this helps.
alfa-74 is offline
post #417 of 425 Old 12-17-14, 05:47 PM
Myles
I leave my MiniDSP on all the time. I manually turn my iNuke on/off with the power button. No pops, thumps or anything. My previous EP4K used to thump a little w/ turn-on, but not bad.
Re: Furman stuff (MP-20Q + PowerLink). Another $500 to turn the system power on/off? Does the expense sink-hole of this hobby ever end??
<-- SOLD!
Wooderson is offline
post #418 of 425 Old 02-09-15, 03:01 PM
New Member
I run a nu1000dsp in bridge mode. Using a 4p speakon connector(+1 and +2 connected).
What i find weird is that both volume knobs work, is this right or have I done something wrong?
Are both knobs supposed to be on the same level?
nielsvanbaal is offline
post #419 of 425 Old 02-09-15, 04:40 PM
Larry
nielsvanbaal wrote: View Post
Both channels of the amp are working together in bridged mode...
Use the knob for Channel A to set your gain and rotate the knob for Channel B all the way counter-clockwise to the "OFF" position.
HomeTRNut is offline
post #420 of 425 Old 03-10-15, 04:14 AM
New Member
Hey there fellow bassheads, just finished reading all posts, phew.... Couldn't find the answer in here either so I thought since it's related to all inukes- here it goes.
I'm getting inuke 6000 to power my 2 SI HT 18 D2 in single sealed box. My plan is to wire each of them to 4ohms and connect single woofer to each channel. BUT. How I know that the signal is going reach each of the driver at the exact same moment so the drivers won't fight each other in a single box? I understand that the difference might be somewhere in 0.00000000001 region but still. Or am I overthinking too much about it? Thanks for any input and accept my apologies if the question was noobish :-)
NoMoneyNoHoney is offline
amps , behringer , class-d , coming , inuke
