Amp Recommendation - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 20 Old 04-25-07, 05:35 PM
Steve
Re: Amp Recommendation
sure you could, but you may not get enough voltage to actually get some good sound out of you're sub.
the clean box just increases the voltage so the amp will output more based on that new higher input voltage.
ccdoggy is offline
post #12 of 20 Old 04-25-07, 09:09 PM
Will
Send a message via AIM to WillyD Send a message via Skype™ to WillyD
blaser wrote: View Post
Well, these amps look great, but are you sure they are within budget????
B Rgds
Blaser
I wasn't aware the OP provided a budget.
And you can get the PLX amps used for a much better price.
WillyD is offline
post #13 of 20 Old 04-26-07, 06:04 PM Thread Starter
Boomer
I guess I'd better clarify my budget. My target range is:
Amp: ~$250-350* (*w/ Cleanbox if required)
BFD 1124P: ~$60-100 (off Ebay or new)
I don't plan on running two subs (space constraints) or adding an additional driver to my present one (they're hard to find anyway). As for the amp choice, it will either be the Buttkicker or the Behringer. The (mild) concerns I have now are twofold: 1) bridging the pro amp (longevity/reliability) & 2) running a Buttkicker amp outside of it's intended application.
southworth is offline
post #14 of 20 Old 04-26-07, 09:02 PM
Will
Well you put that concern to rest. There are numerous folks out there including me, using the BKA with their sub. I am very pleased.
But the EP2500 should perform very well for you, should you choose it. I'd do what ccdoggy said, and bridge it (wire the VCs in series), should you choose to get it.
WillyD is offline
post #15 of 20 Old 04-30-07, 10:22 PM
gilbypoleadamson's Avatar
Gil Smash
How is the buttkicker when used as a sub amp?
gilbypoleadamson is offline
post #16 of 20 Old 05-01-07, 08:26 AM
JorgenMan's Avatar
Aaron
I'm using a Buttkicker to power two RL-p 15"s in an IB now, and it's worked great, although I haven't even come close to giving the amp a good workout. It's nice to have no fans, and no worrying about needing a Cleanbox or whatnot.
JorgenMan is offline
post #17 of 20 Old 05-03-07, 12:24 AM
New Member
Paul
The buttkicker also has auto-on and an RCA input, better match for LFE outputs on HT receiver/processors, though there are certainly workarounds for this if you're going with a pro amp.
deneb is offline
post #18 of 20 Old 05-08-07, 08:53 AM
Darren's Avatar
Darren
I'm a big fan of the Behringer EP 2500. Gobs of power at a reasonable price and for $8 you can put a panaflow fan in that will make it silent beyond 2 feet. Mine is powering 4 RL-P 15's.
Darren is offline
post #19 of 20 Old 05-08-07, 10:03 AM
1Michael's Avatar
Michael
I am using the 1000 watt Buttkicker with an RL-P15 and RL-P18 and it works fine. My assumption was if it can move a 2 pound piece of metal, it can probably move a cone. It seems to work just fine.
1Michael is offline
post #20 of 20 Old 05-08-07, 07:19 PM Thread Starter
Boomer
Thanks for all your help guys!
I decided to get a Buttkicker amp from Musician's Friend.
It's on backorder right now (till 6-1 07). Can't wait to hook it up.
amp , recommendation
