Amp Recommendation - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 20 Old 04-24-07, 10:27 PM Thread Starter
Boomer
Amp Recommendation
I've presently got a AVA 15 in a 4^3 ft sealed enclosure and I want to power it with a pro amp. I also plan on adding a BFD to eq the low end response. The AVA 15's pnom 800W. Since this is a dual 2 ohm driver what would be a good pro amp to mate with it?
southworth is offline
post #2 of 20 Old 04-25-07, 12:34 AM
Dan
Send a message via MSN to Danny
Re: Amp Recommendation
Crown, Lab Gruppen, Yorkville Make good amps and i'm pretty sure that they can all handle 2 ohm loads (make sure you specify 2ohm if ordering Yorkville they have 4 ohm versions as well)
Danny is offline
post #3 of 20 Old 04-25-07, 10:40 AM
Blaser's Avatar
Ahmed
Send a message via MSN to Blaser
What about Behringer Amps?
Blaser
Blaser is offline
post #4 of 20 Old 04-25-07, 03:46 PM
Brian
i just bought at buttkicker bka-10004 off ebay for under 200. May want to keep that in mind. 2100W into 2 ohms
bonehead848 is offline
post #5 of 20 Old 04-25-07, 03:50 PM
Will
Send a message via AIM to WillyD Send a message via Skype™ to WillyD
Budget?
The QSC PLX amps deserve a look.
WillyD is offline
post #6 of 20 Old 04-25-07, 04:41 PM Thread Starter
Boomer
I am on a budget a bit!
Maybe I've got two ways to go about this (I hope). I could get the Europower 2500 and run both channels to each of the AVA's coils. Or get the Buttkicker and run the AVA's coils in series. Right now my AVA's coils are wired in serie for a 4 ohm load. Suggestions?
Also, will I have any problems using a BFD with either amp? I'll do a Google search on the PLX amps in the meantime.
post #7 of 20 Old 04-25-07, 05:02 PM
Steve
I would get the EP2500, then connect it as a 4Ohm load bridged so you get some good power. Ignore the ratings on the EP2500 as it will not put out 2400watts, or even close to it. but it will power the AVA quite nicely.
ccdoggy is offline
post #8 of 20 Old 04-25-07, 05:07 PM
Blaser's Avatar
Ahmed
WillyD wrote: View Post
Budget?
Well, these amps look great, but are you sure they are within budget????
B Rgds
Blaser
Blaser is offline
post #9 of 20 Old 04-25-07, 05:27 PM Thread Starter
Boomer
The Pxl series is out of my range. Will it be ok to connect the BFD to my pre-pro & sub without a cleanbox?
post #10 of 20 Old 04-25-07, 05:28 PM Thread Starter
Boomer
Excuse the spelling. I meant PLX.
amp , recommendation
