2 subs one plate amp - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 20 Old 03-16-11, 09:24 PM
bambino's Avatar
bambino
Re: 2 subs one plate amp
Zeitgeist wrote: View Post
I generally feel that if you need something above 500W or want to power multiple drivers (especially 18") - it's a good idea to consider an amp like a Behringer 2500/4000.
I feel that above 500W it becomes less cost effective to use a plate amp.
Good point but some setups or just personal prefrences require a plate amp.
bambino is offline
post #12 of 20 Old 03-16-11, 09:32 PM Thread Starter
Devon L.
what else would i need to go along with the behringer amp? BFD, something with HP and/or LP filters on it?
adio is offline
post #13 of 20 Old 03-16-11, 09:37 PM
bambino's Avatar
bambino
Choose a driver and cabinet design and what you are looking to get out of it (music/movies) and we can help you abit better.
bambino is offline
post #14 of 20 Old 03-17-11, 08:42 PM Thread Starter
Devon L.
oh well the other piece of this thread was moved.
so how about hooking up 2 plate amps to 1 sub? i went over to apex's site and had my eye on 2 apex seniors......... any thoughts?
adio is offline
post #15 of 20 Old 03-17-11, 08:56 PM
Zeitgeist's Avatar
Jim
Generally a bad idea - because you'd need to have the gain identical on both.
Sounds easy enough - but in reality it's better to just get a powerful enough amp.
Zeitgeist is offline
post #16 of 20 Old 03-17-11, 09:08 PM Thread Starter
Devon L.
lols, ok
adio is offline
post #17 of 20 Old 03-17-11, 10:24 PM
bambino's Avatar
bambino
Jim is right, that it is easier said then done but with the proper knowledge and tools it is simple to equalize gain on 2 seperate amps. I would suggest for simplicity just getting a more powerful amp that can deliver the power needed for the subs you have in mind however.
bambino is offline
post #18 of 20 Old 03-18-11, 02:57 PM Thread Starter
Devon L.
thanks guys, i'm on it.........
adio is offline
post #19 of 20 Old 02-22-12, 05:07 PM
nick24u
Hi, I confirm you should get a standard 2 channel rack amp powerful enough for the biggest sub, then install the amp (or not) in one of the cabinets and connect each cab on each output of the amp. This will allow you to setup each sub at the right level without any risk of failure from the amp as if you connected the two subs on one channel only. As you use a powerful 18, I'd suggest a (real) 2x500RMS under 8ohms minimum.
nick24u is offline
post #20 of 20 Old 02-22-12, 07:40 PM Thread Starter
Devon L.
nick24u wrote: View Post
thanks nick
adio is offline
plate , subs
