Crown XLS 602D $229 AR - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 14 Old 06-06-07, 07:14 PM
Dan
Send a message via MSN to Danny
Re: Crown XLS 602D $229 AR
I've never had a problem running the crowns at 2ohms. It wasn't that model though (Amps I used put out more power) and they never shut down even when driving them hard.
Danny is offline
post #12 of 14 Old 06-06-07, 07:35 PM Thread Starter
FireWalker877's Avatar
C
Yeah, the XLS is their low-end model. I decided to play it safe, and power an 8 ohm TC2k. The amp was rated for 4 ohms, but I figured 1200W would give me all the output I needed without the risk of overheating. I just glued my first joint on the enclosure, I hope I used enough Titebond!
FireWalker877 is offline
post #13 of 14 Old 06-14-07, 10:49 PM
Dan
The Lab Gruppen Amps are good to use, run them down to 2 ohm and still no problems even at maximum output. The C series may be good as you can set them to switch on in a certain order (using your computer) and are able to make settings which other amps don't have. Really good to work with
Danny is offline
post #14 of 14 Old 06-17-07, 10:36 AM
kouack
Yes LAb are very good amp, but 10 X the price of an XLS so i'm not sure will fit his bill and i'm not sure people needs Lab amp in their houses anyway, QSC and Crown makes excellent amp's that will fit anybody need :-)
kouack is offline
$229 , 602d , ar , crown , xls
