Help me connect my Peavey IPR DSP3000 amp - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 3 Old 09-28-11, 07:34 PM Thread Starter
Marce
I'm new to this type of amp/connections and have a few questions on how to connect my Yamaha receiver-amp- sub combination;
1. Do I need one RCA(male) to XLR(male) cable to go from the one sub preout output of my receiver to one of the Peavey's XLR (Either A/B) inputs or do I need two RCA(male) to XLR(male) cables to go from a Y RCA cable adapter connected to the receiver's preout to the dual XLR inputs of the peavey amp?
2. I bought one Speakon (4-pin) connector. Do I need two of them to to connect the two subs I have, a dual sealed opposed sub system, to the Peavey amp which will run in stereo mode? If so, I will also need two Speakon cables (male to male) to go from the amp's dual Speakon outputs to the two Speakon sub connectors, right? I need a cable of about 10', will 14ga be sufficient? Also, do I connect each sub to the +1/-1 pins of each Speakon connector? The Speakon cable does the job of electrical wire to carry the "juice" to the subs, only better, right? Thanks.
spanish68 is offline
post #2 of 3 Old 09-28-11, 10:31 PM
GranteedEV's Avatar
Kick logic 2 da curb
Re: Help me connect my Peavey IPR DSP3000 amp
spanish68 wrote: View Post
If you've two subwoofers being driven off the peavy, you want a Y adaptor driving each individual channel of the peavey separately. If you're only driving one subwoofer, there is no point in a y-adaptor.
Yes. Each amplifier output needs to connect to each individual driver.
14 awg will likely suffice, although for high powered applications like this, I prefer the extra heatsinking of 12 awg. It's probably an irrational approach as even your home wires are probably 14awg.
The speakon cable is no different from a speaker cable; it just uses neutrik connectors. The only advantage of the neutrik connector, is how easy to connect it is.
GranteedEV is offline
post #3 of 3 Old 09-29-11, 03:18 PM Thread Starter
Marce
GranteedEV, very clear answers, got it. Thanks.
amp , connect , dsp3000 , ipr , peavey
