ep2000 question - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 6 Old 11-05-11, 10:48 AM Thread Starter
ep2000 question
i just received my ep2000, to power my 2-sealed mfw-15s. i have a sony 10"er at the moment. im still waiting on my bfd, but just to see how it sounds i unplugged my sony and hooked up the ep2000 into the denon receiver with an rca to xlr plug and speaker wire to my two subs. but when i turned it on, they hardly make noise. i tried with teh clip limiter on and off i have the mode on parallel cause im only using one input. i have the filter turned off on it. i didnt rerun audyssey yet, and i turned the sub channel to +6. i have hooked one of my subs up to my sony amp and it sounds great, but the ep isnt doing anything. the yellow signal light is coming on but its hardly making a sound. it should be rocking, any suggestions?
fridge011 is offline
post #2 of 6 Old 11-05-11, 09:35 PM Thread Starter
Re: ep2000 question
Has this happened to anyone?
post #3 of 6 Old 11-06-11, 06:27 AM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: ep2000 question
Just to clarify - for parallel mode, dip switches #4 and #5 should be set to the right, and #6 and #7 should be to the left.
Did you try adjusting the EP’s gain controls?
It might be better to use standard RCA to 1/4” TS cables rather than XLR.
Also, if you're using Speakon connectors make sure they are wired correctly. And double check the polarity on your two subwoofer speaker wire connections, including internally (inside the box itself). If one of them is backwards it’ll suck the life right out of your output.
post #4 of 6 Old 11-06-11, 08:32 AM
New Member
ma7rix13
Probably a line balancing issue.
ma7rix13 is offline
post #5 of 6 Old 11-06-11, 10:53 AM Thread Starter
Re: ep2000 question
Alright I got it. It mist have been the cable. I used a 1/4 and it's working fine. I can't wait till I get my bfd in and set up so I can bug y'all with bfd questions. Lol. But really I'm reading up on it a whole lot and hopefully it wont be too bad. I've been waiting to watch a few movies till I get everything set up. Thanks for your help
post #6 of 6 Old 11-06-11, 04:11 PM Thread Starter
Re: ep2000 question
It seems when i play blu rays they hit hard, but when I watch cable or play pandora through ps3 they hardly make a noise
ep2000 , question
