Behringer iNuke NU1000 Amp Amplifier Fan Swap How To w/ PICS - Page 14 - Home Theater Forum and Systems - HomeTheaterShack.com
post #131 of 138 Old 03-01-15, 11:20 AM
Re: Behringer iNuke NU1000 Amp Amplifier Fan Swap How To w/ PICS
BTW I like funkingitup's solution up there.
Is the fan in the original location, a quieter upgraded one?
giskard is offline
post #132 of 138 Old 10-08-15, 01:48 PM
I was thinking of doing what funkingitup did with his 3000 to my 1000 non DSP once it came in. Just get rid of shroud and put a big fan on top blowing out.
cajun_duck is offline
post #133 of 138 Old 01-09-16, 07:54 PM
rselby's Avatar
has anyone placed sound deadener( dynamat type stuff ) on the fan shroud....seems to me that this will add mass to the flimsy thin plastic fan shroud and combat the resonance ( and sound ) ....just a thought...but the fans do sound like a plane taking off when they are on full speedc
rselby is offline
post #134 of 138 Old 01-22-16, 04:16 PM
daddieo's Avatar
Daddieo
Just popped the top on my new 3000 and the fan was installed to blow in and this seemed a bit odd to me what with the shroud set-up. If doing a fan swap and removing the shroud, along with heat-sinks, would it not be better to have the fan exhaust the heat rather than just move the heat around???
daddieo is offline
post #135 of 138 Old 02-19-16, 09:40 AM
Just received an NU3000DSP yesterday. Plugged it in and turned it on. Sounded like a vacuum cleaner LOL. I just got done swapping the stock fan out with a Noctua NF-A8 FLX. Wow, what a difference. Highly recommenced. I also added the aluminum heat sinks as shown in prior posts. Took me all of 30 mins to do the entire mod.
Mirage_Man is offline
post #136 of 138 Old 03-18-16, 05:15 PM
I have racked up a little over a year of daily use with zero problems from the 140mm top-mount mod. Has anyone hit 2 or 3 years with their Noctua mods? It's great to hear how they hold up.
funkingitup is offline
post #137 of 138 Old 01-12-17, 09:44 AM
New Member
Another successful fan swap on a NU3000DSP. I've had my iNuke for 2 years and finally got around to this mod. I couldn't be happier. A Noctua NF-R8 redux-1800 is what I used and for all intents and purposes it's silent. The connector on the NF-R8 was loose when I attached it to the board so I removed it and used the stock connector. Well worth the $10 and 1 hour of labor.
fixthedoor is offline
post #138 of 138 Old 09-10-17, 11:11 AM
HTS Senior Moderator
fusseli's Avatar
iNuke Fan Swap and DIY 12v trigger
I replaced my upgraded fan the other day, it was an Arctic Cooling F8. The bearings were starting to wear out and a droning noise was getting louder. Not bad but I knew what the cause was. I used to leave my nu3000 on 24/7, before my 12v trigger mod, the fan life was pretty good considering it was about three years of being on 24/7 continuous. For a replacement I used a Noctua NF-R8 Redux. I think Noctua makes the nicest 12v fans around.
Here's a pic of my 12v trigger relay to turn the inuke on and off with the AVR, before taping it up to cover the connections and support the wires. My old Onkyo 818 didn't have 12v trigger but my new Denon X3300W does. The 20amp 12V relay was I think all of $8 on Amazon and the rest of it was spare cords and parts I had laying around. Works like a charm and my living room no longer has an orange night light from the inuke
Behringer iNuke NU1000 Amp Amplifier Fan Swap How To w/ PICS-20170909_151900-copy.jpg
fusseli is offline
1000 , amp , amplifier , behringer , fan , inuke , pics , swap , w or
