Stand alone amp - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 5 Old 01-18-13, 12:37 PM Thread Starter
Stand alone amp
Looking at a Dayton SA 1000 stand alone amp from CCS. Would this amp be enough to driver two 15" subs for home theater?
stilly is offline
post #2 of 5 Old 01-18-13, 12:53 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: Stand alone amp
Yes, the amp can drive two 4- or 8-ohm subwoofer drivers.
post #3 of 5 Old 01-18-13, 12:59 PM Thread Starter
I should have worded it differently. Would the amp have enough power to drive two 15" subwoofers (4 ohms) in a home theater setting. Says the amp is rated at 950 watts but I believe I've read somewhere its really only about 650 watts so only 325 per sub doesn't sound very good.
stilly is offline
post #4 of 5 Old 01-18-13, 04:36 PM
Re: Stand alone amp
Looking closer at the specs I see it’s a mono amp; I was thrown by the dual inputs. So for two drivers, that 950 watts @ 4-ohms ends up being 475 watts to two 8-ohm speakers.
It’s not easy to give you a definitive answer as to whether or not that’s enough power, because it depends on lots of things - your project, the size of your room, how loud you like to play the system, etc. Specifically to the former, 475 watts per driver might well be enough if you’re going with a high-output ported design, but that 475 watts won’t go nearly as far with a small sealed enclosure that requires lots of EQ boost at the lowest frequencies to make up for the small box.
post #5 of 5 Old 01-18-13, 08:52 PM
fusseli's Avatar
Re: Stand alone amp
It depends heavily on what 15" subs you are talking about, and what enclosure they will be in. The easy answer is yes: 600 -1000W is plenty for two 15" subs, in general.
fusseli is offline
amp , stand
