Need 2ohm stable dedicated subwoofer amp. - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 22 Old 03-10-13, 11:45 PM
Mike P.'s Avatar
Mike
Re: Need 2ohm stable dedicated subwoofer amp.
GTi's are dual 6 ohm as far as I know.
We're all in this together!
Mike P. is offline
post #12 of 22 Old 03-11-13, 09:24 AM Thread Starter
Mike P. wrote: View Post
You are correct. Sorry for the mistake.
Help Please is offline
post #13 of 22 Old 03-11-13, 10:51 AM
Mike P.'s Avatar
Mike
What size of GTi's do you have and what is the net volume of the cabinet they are in?
Mike P. is offline
post #14 of 22 Old 03-11-13, 12:27 PM Thread Starter
2 15"; 4.6 cu ft per enclosure.
post #15 of 22 Old 03-12-13, 11:42 PM Thread Starter
I'm strongly considering going with two Emotiva XPA-1 amps to run the JBLs. I like the idea of a large amp sitting atop each subwoofer cabinet. I just stumbled upon these amps and have not done much research. The only complaints on them seem to be geared toward people who use them in a full range setup. Their business model seems solid. Design in the US, have them build the amps in China, and then cut out the middle man by selling them direct. I'm not concerned about the price being too low when you can sell a 2,400 watt pro amp for $600. Plus, they come with a 5 year warranty. I called their customer service and they said that the amp will run down to 3 ohms but it will run hotter.
post #16 of 22 Old 03-13-13, 04:04 AM
Mike P.'s Avatar
Mike
Modeling shows the 15's impedance doesn't drop below 4 ohms until 15 hz. And the impedance will rise as soon as the coil heats up.The Emotiva XPA-1 is awfully pricy for a 500 watt amp.
Mike P. is offline
post #17 of 22 Old 01-18-17, 12:00 PM
New Member
I know this is long past the time this message board was opened... but I'm surprised no one suggested hooking the two subs up in a series circuit to add the ohmage together, giving you a 4 ohm circuit to work with as opposed to 2 - 2 ohm circuits. Simply running the positive wire from the amp to the positive of one sub, and the negative from the amp to the negative of the second sub, and a connecting wire between the two subs would have created this so you would have a 4 ohm stable circuit.
Hollander79 is offline
post #18 of 22 Old 01-18-17, 01:55 PM
ellisr63's Avatar
Ron
Hollander79 wrote: View Post
If you do that... Can you EQ them individually still?
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (5) JBL 8340As, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, Oppo UDP-203, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #19 of 22 Old 01-19-17, 03:10 AM
Truthsayer's Avatar
Cant believe no one has said it. But you need and want to go with the cerwin vega CV-5000.
Truthsayer is offline
post #20 of 22 Old 01-19-17, 07:06 AM
willis7469's Avatar
http://www.speakerpower.net/
Sent from my iPhone using Tapatalk
willis7469 is online now
2ohm , amp , dedicated , stable , subwoofer
