16hz HPF - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 23 Old 10-30-13, 07:36 AM Thread Starter
Robbo
16hz HPF
Hello people.
I have finally got my sub, amp and power supply but I have an issue that I need to limit my sub for anything less than 16hz because the drivers are going beyond excursion
Any idea how I would start to make one or better yet one I can buy off the shelf, ideally an adjustable HPF?
Thanks
Craig
CraigRobbo is offline
post #2 of 23 Old 10-30-13, 08:07 AM
HTS Moderator
doug
Re: 16hz HPF
An unbalanced miniDSP or a Reckhorn B-2 would do the trick. The miniDSP would have many more options, but is a bit more expensive. I have both and would get the miniDSP 10:1 if you like to tinker.
dougc is offline
post #3 of 23 Old 10-30-13, 08:46 AM
Paulcet's Avatar
Paul
What's the input impedance on the amplifier? (And is the amp just for the sub?)
Could easily put a capacitor on the input.
Paulcet is offline
post #4 of 23 Old 10-30-13, 10:01 AM
HTS Senior Moderator
fusseli's Avatar
Re: 16hz HPF
Paulcet wrote: View Post
+1. I have done this before with accurate results.
If a 1st-order filter is all you need, this is by far the simplest and cheapest solution.
fusseli is offline
post #5 of 23 Old 10-30-13, 10:51 AM
fusseli wrote: View Post
This is interesting. I'm also looking for getting a minidsp, but this could be a short term solution. looking forward for more details
alfa-74 is offline
post #6 of 23 Old 10-30-13, 12:17 PM
robbo266317's Avatar
bigbadbill
Re: 16hz HPF
Using the formula for HPF and a spreadsheet you get the following results for a 16 Hz cutoff and assuming your amp's input impedance is 47 kΩ or greater, then the combined impedance of R1 and R_amp (R2) is 8.25kΩ
Then using the info from here: http://www.t-linespeakers.org/tech/f...ssiveHLxo.html you get R1 as 10 kΩ and C1 as 1.2 micro Farad
-Bill
Silence is golden but duct tape is silver.
DIY completed:
robbo266317 is offline
post #7 of 23 Old 10-30-13, 06:43 PM Thread Starter
Robbo
Re: 16hz HPF
Thanks guys, I am not mega clued up on the elctronic side of things so I am unsure of input impedance, is there an easy way to find out?
The amp is dedicated only to the subwoofer.
As above if a 1.2Micro farad will do, how would I connect it, across the lines or in series?
Thanks for the help
Craig
post #8 of 23 Old 10-31-13, 01:21 PM
bigbadbill
Re: 16hz HPF
Most modern amps will have an input impedance of at least 47 kΩ so you can ignore it.
The setup would be: Sub Output from receiver goes into the capacitor with the resistor after it connected to earth. (As per the picture, the sub out is on the left and the power amp input is on the right.)
-Bill.
DIY completed:
post #9 of 23 Old 11-01-13, 07:36 AM Thread Starter
Robbo
Re: 16hz HPF
Please excuse the very poor MSpaint drawing, is this how I would physically connect it up?
Craig
post #10 of 23 Old 11-01-13, 08:17 AM
Paulcet's Avatar
Paul
Re: 16hz HPF
Yes, if you go with a single component filter. Which is what I would do probably. And Fusseli too. You would need a .211 uF capacitor. (Someone please check my math and correct me if I'm wrong!)
Paulcet is offline
16hz , hpf
