subsonic filter for ported sub - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 4 Old 11-04-13, 08:33 PM Thread Starter
Hi - I have two ported subs (Dayton RSS 315hf-4) running with correction with BFD and REW. I need a subsonic filter, the crown amp I am using (xli 1500) does not have crossovers or EQ. I need a subsonic filter at around 17hz to prevent overexcursion of driver? What other options for an inexpensive in line subsonic filter?
bommers is offline
post #2 of 4 Old 11-04-13, 08:43 PM
HTS Senior Moderator
fusseli's Avatar
Re: subsonic filter for ported sub
There are rumors on the web that the newer Crown XLS amps have a built 20Hz HPF. Not sure if that applies to your XLi, but it could? You might do some research and/or contact Crown directly to confirm before you worry about adding an external filter.
fusseli is offline
post #3 of 4 Old 11-04-13, 09:21 PM Thread Starter
Thanks Russ, I will look into that. These new subs I build rock, (5 cubic feet, tuned to 21 hz. ) but I don't want them to bottom out like my old sub used to with home theater use. So far so good with movies like Pacific Rim, but I also use for music at least 50%.
bommers is offline
post #4 of 4 Old 12-01-15, 09:56 AM
Did u figure out a filter at 17hz?
guimond47 is offline
filter , ported , subsonic
