Behringer iNuke DSP Help - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 17 Old 03-16-14, 07:37 PM
HTS Senior Moderator
fusseli's Avatar
Re: Behringer iNuke DSP Help
Potato-potatoe. Same thing in the end.
fusseli is offline
post #12 of 17 Old 03-16-14, 07:50 PM Thread Starter
Thanks man. So no rolloff below 20hz to worry about? Think I should hpf at 20hz along with the ls12 or alternate potato?
I am obsessed.
Pete
corradizo is offline
post #13 of 17 Old 03-16-14, 08:29 PM
fusseli's Avatar
You should disable any HPF if your subs are sealed!!
fusseli is offline
post #14 of 17 Old 03-16-14, 08:43 PM Thread Starter
fusseli wrote: View Post
Thanks for clearing that up. Your help is greatly appreciated. Can't thank you enough!
post #15 of 17 Old 03-16-14, 08:52 PM
fusseli's Avatar
My pleasure, let us know how your subs sounds once you get everything setup!
fusseli is offline
post #16 of 17 Old 07-24-14, 07:09 PM
Bstloukal1's Avatar
I believe I've set mine at the quote from ltd but can someone confirm as the a possible screen shot or as to which tabs on the dsp setting should be adjusted. Here is what I did a while ago. On the filter/xover tab I set the highpass at 20hz with a buttersworth at 12db. On the paramedic eq tab I set a HS12 at 20hz with a -5db gain. Is this correct or do I need to do Something a little more or different to achieve a lower than 20hz filter. I think was doe to get me around 15hz. Let me know thoughts or if there are other ways
Bstloukal1 is offline
post #17 of 17 Old 07-24-14, 09:50 PM Thread Starter
You shouldn't have the xover setting at anything. Your reciever would do that. You make the hpf in the EQ page by doing a hs12 with -gain and the you bump the overall gain on the xover screen by adding in the equivalent positive gain. I didn't need to do this at all because my subs are sealed. I assume this is a ported sub? I can't do screenshots because the software only shows 20hz so the effective filter is to the left of where you can see on the screens.
behringer , dsp , inuke
