iNuke 3000 DSP fan mod question - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 3 Old 04-25-14, 01:01 PM Thread Starter
EndersShadow's Avatar
Ender
So I am about 99% dialed into a "MartyCube" build using a Dayton 460HO 18" driver with a iNuke 3000 DSP. The iNuke will be bridged and set to give a max of 1100 watts to the Dayton.
Here is my question.
I see some differing info on what the stock fan's voltage is on the iNuke. I plan to replace it with a Noctua NF-R8-1800 which is MUCH quieter.
However have read that the stock fan is 17v rather than the 12v the Noctua is. If so I believe I need to add a resistor between them so as to lower the voltage to the Noctua to the 12v it is looking for.
Is this right?
Also I plan to install these heatsinks on the existing ones to help the amp dissipate heat better.
In addition I plan to add dynamat to the fan shroud (and possibly make the front part less constrictive) as well as the chassis of the amp. I believe that should further reduce the noise the amp makes to almost non existent.
Does anyone see ANY problems with this scenario?
EndersShadow is offline
post #2 of 3 Old 04-26-14, 03:02 PM
Re: iNuke 3000 DSP fan mod question
I have an inuke 3000 dsp also.
It sits about 9 feet from my listening position.
It was very loud stock. I replaced the fan with a $5 Dynex fan from best buy Model: DX-FAN101. 26 dba and 31 cfm. Can't hear it now at all unless I put ear within a foot of it.
I used heatsink about your size also. Still use unmodified stock shroud and no other modifications.
Amp works great with no heating issues.
cellarnoise is offline
post #3 of 3 Old 04-30-14, 12:26 PM Thread Starter
Ender
Decided to go another route. Going with a Dayton SA1000. Works for me as my sub (now purchased) is a Stereo Integrity D2. @ 4 ohms its only rated for 600 wpc and the Dayton (on paper) has lots more power than it needs.
So I should be fine and this way no mods needed. Just have to purchase a MiniDSP for the EQ aspect.
3000 , dsp , fan , inuke , mod , question
