Samson S-Convert (alt. to ART Cleanbox) - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 18 Old 01-13-12, 01:02 PM
Re: Samson S-Convert (alt. to ART Cleanbox)
What about a mic preamp I can get a good deal on a tube preamp
overlord1330 is offline
post #12 of 18 Old 01-13-12, 04:54 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
They only accept mic-level input signals, which are extremely low.
post #13 of 18 Old 01-13-12, 11:18 PM
What do u recommend
post #14 of 18 Old 01-14-12, 08:09 AM
Using nothing at all, if possible. These things add noise to the system (at least if youíre using them for the main channels), and thereís a good chance you donít even need it. Iíd suggest reviewing Part 7 of my gain structure article (you can find the link in my signature). Iím sure youíre looking for an inexpensive solution, so if you really want/need one I suggest finding a used S-Convert. The only alternatives Iíve come across cost in the $200 range.
post #15 of 18 Old 01-14-12, 08:19 AM
i have a crown xls 2500 for my DIY sub but my pioneer elite receive sub out put I'd only 335mv the crown needs 1.4v that is why I need a convert right will a art clean box work?
post #16 of 18 Old 01-14-12, 10:27 AM
Is that the output voltage you actually measured, or what Pioneer specs? Often the manufacturer’s figures are grossly under-rated.
The ART suffers from a mild low freq roll-out , so it might not be what you want for a subwoofer. See here. I think somewhere on this Forum there’s a thread about modifying it, if you’re brave enough to tackle that.
That said, it’s down only 5 dB or so at 20 Hz. Unless your sub digs below 10 Hz, that could easily be fixed with an equalizer.
post #17 of 18 Old 09-07-14, 01:37 PM
New Member
Angry Re: Samson S-Convert (alt. to ART Cleanbox)
I opened up my s-convert and many bad caps including ones in the power supply .I replaced them and the s-convert works great .
So guys if you have the s-convert open it up and check your caps .
cdx304 is offline
post #18 of 18 Old 10-12-14, 12:42 PM
John
cdx304 wrote: View Post
cdx,
How did you go about checking the caps? My S-Convert has one channel that is much noisier than the other.
JSS
maxmercy is offline
alt , art , cleanbox , samson , sconvert
