-   Subwoofer Amps | High Pass Filters (https://www.hometheatershack.com/forums/subwoofer-amps-high-pass-filters/)
-   -   what suggestion to set HPF (https://www.hometheatershack.com/forums/subwoofer-amps-high-pass-filters/119066-what-suggestion-set-hpf.html)
apilon 04-10-15 06:29 PM
Good evening
I am almost done with buiding a micro marty and i need to tune the port to 23 Hz ..........I will be using a Behringer EP4000 to drive that sub so my question is what do you recommend to set the HPF to 23 Hz ??
Thanks
Alain
nova 04-11-15 12:29 PM
Re: what suggestion to set HPF
I'm no expert but I thought you'd set it 1/2 octave below your tuned frequency, so 17 Hz?
I'm sure someone with more knowledge on the subject than me will be able to provide you with a better answer.
apilon 04-11-15 02:59 PM
nova wrote: (Post 1171626)
Hi Mark
Thanks for the answer, what i am looking for is mot in term of what additional equipment do i need to get to setup the HPF
muzz 04-11-15 06:33 PM
MiniDsp is what most folks use when they don't have onboard DSP.
I assume that when you modeled your sub that you know where to set the HPF, I'm not sure what you mean by "Tune the port" though.
Wayne A. Pflughaupt 04-11-15 10:03 PM
apilon wrote: (Post 1171786)
Hi Mark
Are you looking for a DIY solution or something off-the-shelf?
apilon 04-12-15 12:36 AM
Wayne A. Pflughaupt wrote: (Post 1172153)
Off the shelf unless the DIY solution is easy to implement
apilon 04-12-15 12:41 AM
muzz wrote: (Post 1172026)
Hi
I need to set it at 23hz since it will be vented
mikmaz 04-12-15 04:49 AM
I use a balanced minidsp 2x4. I use it to set hpf for my ported ultimax 18. I can set it at anywhere from 10hz and up at whatever slope you want. You can experiment with it get it where you want
Excellent product
Wayne A. Pflughaupt 04-12-15 08:35 PM
Another option is the Yamaha YDP2006 digital parametric equalizer. It has 24 dB/octave HP and LP filters. Not as flexible as the miniDSP, but easier to operate and connect. And it looks good in an equipment rack. :D
apilon 04-13-15 09:28 PM
Wayne A. Pflughaupt wrote: (Post 1173138)
Hi Wayne
I have been on the lookout for this one for over a year without succes it seem to be rare to find at a reasonnable price
