-   Subwoofer Amps | High Pass Filters (https://www.hometheatershack.com/forums/subwoofer-amps-high-pass-filters/)
-   -   Behringer iNuke NU1000 Amp Amplifier Fan Swap How To w/ PICS (https://www.hometheatershack.com/forums/subwoofer-amps-high-pass-filters/52124-behringer-inuke-nu1000-amp-amplifier-fan-swap-how-w-pics.html)
GSX-R_Rider 11-17-11 07:14 PM
Behringer iNuke NU1000 Amp Amplifier Fan Swap How-To w/ PICS & VID
8 Attachment(s)
It has been a while since I have posted here - my original EP4000 fan swap thread got stickied so I thought I would post a part 2 of the new iNuke series using a fresh out of the box NU1000 I received this week in the mail.
Upon being powered on the NU1000 had a definite fan noise while sitting on my kitchen table. I was hoping for an audible drop similar to what the EP4000 fan swap had improved on the original EP stock fans. The fan swap I made in the pair of EP4000s I am still using resulted in a very significant db drop yet never seemed to jeapordize the ability of the EP4000s to run cool (even while wired in 2 ohm stereo for extended durations).
The photos attached show the iNuke NU1000 on my kitchen table with the top being removed and the stock fan being swapped for an Adda Inc AD0812XX-D71 (Jameco part # 2095365......approx $8 ea).
Swapping the fan out on the iNuke amp was easier than the EP fans - 6 screws on top and then remove the 4 screws on the back of the amp holding the external fan guard.........then it is a simple matter of soldering on the new lead to the pigtail from the plug and the new fan bolts into place perfectly.
The bad news......the new Jameco fan IS quiter than the stock fan but it is NOT as significant of a drop as the improvement seen in the EP4000 fan swap. At best, I see the Jameco part as a temporary improvement.
If others have swapped their fans in the iNuke series and have had better results and more significant fan noise reductions please post your fan part # and vendor!
I have yet to test this amp, it will be powering a Dayton Reference Series RSS390HO-4 15" sealed sub. I will post my impressions of this amp in the next couple of weeks as the new system gets pieced together.
Mike P. 11-17-11 08:37 PM
Re: Behringer iNuke NU1000 Amp Amplifier Fan Swap How To w/ PICS
Thanks for documenting the fan swap. This thread has been stickied.
TagUrToast 11-18-11 01:36 AM
I heard somewhere that using silicone mounts on the fan helps to reduce alot of the noise. maybe it is worth a shot if you have some?
GSX-R_Rider 11-18-11 06:54 AM
Silicone mounts may help but my opinion is that the main cause of the wind "noise" isn't so much the fan itself.....it is the sound of the air being vented by the black looking "cover" of sorts that has to be removed before the stock fan can be removed. The stock "shroud" seems to direct the flow of air from the fan in a downward manner and I think the rush of the air from the fan moving inside the shroud is the biggest noise culprit.
You can see in the last photo I posted a pic of the new fan installed without the shroud - when the amp was plugged in and tested this way it was very quiet even with the top off.....however when I then placed the black shroud back in place the noise returned and even with the amp cover back on the fan noise was worse than with the amp opened up being tested with NO shroud in place.
Perhaps the best solution is to ditch the shroud - my only concern would be overheating and diminished protection for the internal amp parts that may need it the most.
My amp will be sitting inside of a rather snug stereo stand and I think this may help mask some of the "wind noise" that I can currently hear with the NU1000 while I test it out on my kitchen table.
Jstslamd 11-18-11 07:33 AM
Could you just open of the shroud a bit by cutting the inlet back some ?
GSX-R_Rider 11-18-11 05:24 PM
Jstslamd wrote: (Post 474560)
Good question - here is the answer - follow the YouTube link below - today I shot a quick HD video of how to replace the fan in the iNuke amps and just posted it to YouTube......in the video I actually took your suggestion and removed the stock fan shroud and "trimmed it" to size. The end result is a somewhat improved fan situation - compared to the aftermarket fan/stock fan shroud, the new combo of aftermarket fan/modified fan shroud is an improvement.
Ultimately ditching the fan shroud would basically reduce fan noise levels to nearly inaudible......or making this simple mod to the fan shroud will get you one step closer to having a quieter fan. Check out the video for a look inside the NU1000.
jdubs 12-02-11 03:43 PM
Is the fan a standard computer fan size? if so, what size is it?
Thanks,
Jim
Ashmanuk 12-18-11 08:43 AM
I wounder if you could glue a thin bit of foam to the inside of the plastic shroud ? That should reduce some noise too.
So the fan is a 12v PC case fan :)) good news as there are lots of silent mod fans out there.
Great video thank you. :clap:
Dave Upton 01-04-12 08:14 AM
If you really want to drop the noise level, I recommend this fan:
http://www.vantecusa.com/front/product/view_detail/113
GSX-R_Rider 01-20-12 04:10 PM
Dave Upton wrote: (Post 485698)
Thanks - may give it a try. I have lived with the current inuke/aftermarket fan combo for a while now and I definitely want to take the fan noise down another notch or two.
I am quite impressed with the amp - the 1000w rating may be a meaningless "max output" but this iNuke1000 bridged to 4 ohm mono driving a 15" small sealed sub is quite powerful.
For $200 I would choose this over comparably priced subwoofer "plate amps" any day of the week.
