-   Subwoofer Amps | High Pass Filters (https://www.hometheatershack.com/forums/subwoofer-amps-high-pass-filters/)
-   -   Need a quiet amp (help) (https://www.hometheatershack.com/forums/subwoofer-amps-high-pass-filters/53109-need-quiet-amp-help.html)
dan711 12-18-11 07:32 PM
I have been running an ep4000 with my Aura NS18 sealed sub for a few months. i performed the fan mod which helped but unfortunately in the long run its still too loud to use all the time so I only use it for action movies.
I'm looking for a quiet amp that can get me close to the 1200-1300 watts I'm supposedly getting from the 1 channel of the ep4000 I'm currently using.
I thought about a used Crown K2 but have been told that the sleep circuit is very sensitive and kicks on regularly.
Any help and/or suggestions would be appreciated.
dan
ironglen 12-18-11 09:47 PM
Re: Need a quiet amp (help)
I'd suggest moving it farther away, of course that is probably not an option since you're asking. Perhaps another member has a quieter fan to use than the one you have: I believe Noctua and Scythe produce the best airflow/quietest fans.
Wayne A. Pflughaupt 12-19-11 10:20 AM
You might look into the Yamaha P-Series amps. They have a reputation for having quiet fans that don’t come on often. Probably gonna cost more than the Behr, though...
dan711 12-19-11 02:04 PM
Wayne A. Pflughaupt wrote: (Post 481920)
You might look into the Yamaha P-Series amps. They have a reputation for having quiet fans that donít come on often. Probably gonna cost more than the Behr, though...
Thanks, Wayne. I saw those Yamaha amps. Looks like the P5000s might work. Its 750w x 2. I could try 1ch and if that doesn't work I suppose that bridging the amp would work for me.
dan711 12-19-11 02:07 PM
ironglen wrote: (Post 481840)
Thanks, Glen but unfortunately I can't move the amp to any other position further from the primary listening pos.
