-   Subwoofer Amps | High Pass Filters (https://www.hometheatershack.com/forums/subwoofer-amps-high-pass-filters/)
-   -   Crown XLS vs EP4000 (https://www.hometheatershack.com/forums/subwoofer-amps-high-pass-filters/69446-crown-xls-vs-ep4000.html)
JimmyLeggs 08-27-13 08:29 AM
Crown XLS vs EP4000
Quick question, I currently have 2 EP4000 which would drive 4 SI 18" (D2 wired for 4ohm) in 24" sealed boxes. One sub per channel.
I got the Class D bug and picked up some XLS 1000 and 2000 to drive my speakers.
I was thinking of replacing the EP4000 with some XLS amps.
How much power would my subs actually need?
Crown XLS:
Specifications
Stereo
Model 4-ohm
1000 350W
1500 525W
2000 650W
2500 775W
Bridged:
Model 4-ohm
1000 1,100W
1500 1,550W
2000 2,100W
2500 2,400W
Would I see any difference in power consumption? I'm assuming the Class D amps would be more energy efficient..that's the end goal really.
dan711 08-27-13 02:11 PM
Re: Crown XLS vs EP4000
I own/have owned Crown XLS and EP4000.
IMO
Efficiency= Crown, quieter=Crown, power=depends which model of Crown, bang for buck=probably ep4000
Realistically you could get by with either the XLS 1500 or 2000 powering your subs. I think the 1000 would lack sufficient power and the 2500 might be a smidge too much.
Mike Edwards 08-28-13 08:32 PM
don't forget that those power ratings on the EP4000/EP2500 are completely over stated. they really only put out about 600-700 watts of true power per channel into 4 ohms
JimmyLeggs 08-28-13 08:36 PM
Mike Edwards wrote: (Post 634752)
Exactly what i was thinking. Still debating if I should go through the hassles of getting rid of my EP4000. I absolutely love the XLS series.
Diamonddelts 09-05-13 04:45 PM
Crown makes great amps. They tend to be quiet and exhibit superior sound quality. However with that being said I feel they give you low power at their respective price points. I would never use anything lower than a Crown XTI 4000 or Crown XLS 2500. And both of those amps were weaker than the Inuke 6000 I use now which is much lower price.
JimmyLeggs 04-29-14 12:43 PM
Digging this one up from the grave but it's time for me to sell some amps.
Subs are Dual 2 Ohm wired for 4Ohm
Currently running 2x EP4000 1 sub per channel.
I also have 2x Crown XLS1000 and 1 Crown XLS2000
With the XLS1000 it would be in Bridge Mode: 1 sub per AMP at 1100 watts, then the XLS2000 would be in stereo, one sub per channel at 650w per channel.
Is 1100 watts too much for that woofer/box combo?
Is 650 enough for that woofer/ box combo?
I don't want to hurt the subs.
Mike Edwards 04-29-14 02:24 PM
JimmyLeggs wrote: (Post 721594)
1100 is fine. A lot of people run these in that range
