DIY Rythmik Audio Direct Servo 12" sealed 56L - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 16 Old 08-23-07, 05:48 PM Thread Starter
Ilkka's Avatar
Ilkka
Re: DIY Rythmik Audio Direct Servo 12" sealed 56L
Yes, two 15"s would be also my choice for serious HT use. Hey...I DO have two 15"s!
Ilkka is offline
post #12 of 16 Old 08-23-07, 09:39 PM
steve nn's Avatar
steve
That you do
steve nn is offline
post #13 of 16 Old 08-23-07, 11:15 PM
It's getting more common all the time.
soho54 is offline
post #14 of 16 Old 08-27-07, 06:15 AM
Russell
I'm feeling left out
Russell
Mitsubishi HC6000 : Carada 88" Precision Series screen : Sony PS3 : Audiolab 8000CD : Audiolab 8000AP : Cinepro 2k6 : XTZ 99.25 fronts & center : M&K Xenon 25 and LCR 25 surrounds : BFD : EP4000: Dual AV15-X 4cu ft sealed subs
russ.will is offline
post #15 of 16 Old 10-31-07, 08:59 AM
paulspencer's Avatar
paulspencer
Very happy to see tests for this kit as I own two. I'd also like to see it tested with extension set to 20 Hz low damping. This would give a more fair comparison to the other subs in low end distortion. For HT use, this would be more appropriate as it's ability to handle LFE with authority is compromised using those settings. Brian indicated that the intention behind 14 Hz extension is for music reproduction.
The results fit with my experience - very accurate mid to upper bass making it very suitable for music. IMO, this is what is most difficult for a sub to do. For home theater it seems to require a bit more SPL to sound loud. Low distortion in the midbass would seem more important to me than down low.
paulspencer is offline
post #16 of 16 Old 11-17-07, 03:35 AM Thread Starter
Ilkka's Avatar
Ilkka
paulspencer wrote: View Post
Unfortunately I don't have that unit in my possession anymore, but I'll see what I can do. I did measure the frequency response using every possible setting (will post them soon) but not distortion.
20 Hz/low damping doesn't yet change the frequency response much. Only around 1 dB down at 20 Hz and 2 dB down at 10 Hz. I would recommend 28 Hz/low or 28 Hz/mid for a larger difference.
Ilkka is offline
56l , sealed
You may not post new threads
You may not post replies
