Subwoofer Tests Explained - Page 5 - Home Theater Forum and Systems - HomeTheaterShack.com
post #41 of 45 Old 08-21-08, 11:54 AM
Mike P.'s Avatar
Mike
Re: Subwoofer Tests Explained
I think he means not identical as in production tolerances.
We're all in this together!
Mike P. is offline
post #42 of 45 Old 08-21-08, 02:37 PM
darrellh44's Avatar
Darrell
Illka,
Which 5400 driver from the Round 5 tests did you use for the recent 75L/200L sealed special test, the one from the sealed or PR'd enclosure?
Thanks,
Darrell
darrellh44 is offline
post #43 of 45 Old 08-21-08, 02:48 PM Thread Starter
Ilkka's Avatar
Ilkka
Ricci wrote: View Post
There were 2 different LMS drivers? All this time I thought that you tested the same one and just switched alignments with the one driver. I never noticed the slight increase in distortion above 50hz for the PR'd system before.
Yes, I have two LMS-5400 18" drivers. But even though the THD graph seems quite different, the difference is mainly caused by the 2nd order harmonic which isn't really that harmful or audible. Maybe some day I'll measure the other driver in that 100 liter sealed box so that we know for sure whether it's a difference caused by the driver or the alignment/box. In any case, I wouldn't worry about it that much.
Ilkka is offline
post #44 of 45 Old 08-21-08, 02:52 PM Thread Starter
Ilkka's Avatar
Ilkka
darrellh44 wrote: View Post
Illka,
Thanks,
Darrell
I used the one from the sealed enclosure.
Ilkka is offline
post #45 of 45 Old 08-21-08, 04:16 PM
Ricci's Avatar
Josh
Ilkka wrote: View Post
Oh i wouldn't worry about that tiny bit of distortion myself either. It barely breaks 5% at a very high output level until 23hz. Still awesome performance, just not quite as squeeky clean as the sealed test.
Ricci is offline
explained , subwoofer , tests
You may not post new threads
You may not post replies
