-   Subwoofer Tests - Archived (https://www.hometheatershack.com/forums/subwoofer-tests-archived/)
-   -   SVS PB12-NSD - #1 (https://www.hometheatershack.com/forums/subwoofer-tests-archived/5768-svs-pb12-nsd-1-a.html)
Ilkka 07-30-07 01:48 PM
SVS PB12-NSD - #1
Manufacturer: SV Sound
Model: PB12-NSD
Provided by: KmoK78
Manufacturer link: SV Sound, L-Sound
Price: 888 EUR
Manufacturer specs:
SVS designed/built long-throw 12" driver
Full-featured 325 watt BASH digital amp
Computer Assisted Design (CAD) enclosure
Dual CNC'd internal braces
Three color choices with removable grill
Front-firing woofer/port for easy installs
Built-in, flush-mount amp configuration
Compliant floor mounts (six)
Patented 4" high-flow flared porting (in and out).
Extra heavy-duty removable 8 foot power cord
"Seamless" cabinet design in three colors
+/-3dB 18Hz-200 Hz anechoic extension
Size: 18" wide x 21" high x 25" deep, 45 cm wide x 52 cm high x 62 cm deep
Weight: 74 pounds, 34 kg
Configuration as tested:
Phase: 0 degrees
Crossover: Bypassed
Orientation: Woofer and port facing the mic
http://www.dvdplaza.fi/galleria/data/954/0065.jpg
http://www.dvdplaza.fi/galleria/data/954/0056.jpg
re: SVS PB12-NSD - #1
Ilkka 07-30-07 01:49 PM
