-   Subwoofer Tests - Archived (https://www.hometheatershack.com/forums/subwoofer-tests-archived/)
-   -   XTZ 99 W12 (maximum extension) (https://www.hometheatershack.com/forums/subwoofer-tests-archived/5770-xtz-99-w12-maximum-extension.html)
Ilkka 07-30-07 12:51 PM
Manufacturer: XTZ
Model: 99 W12
Provided by: Marek Sound
Manufacturer link: XTZ
Price: ??? (not sold in Finland)
Manufacturer specs:
• Construction type: Active subwoofer, Bass reflex gate or may be set as closed box.
• Room-Tuning: With 2pc of included bass-plugs you have 3 different character of sound.
• Dimensions: 350 x 400 x 500 mm (WxDxH), Foot +15 mm, Amplifier +45 mm
• Weight: 30.5 kg
• Frequency: 25-180 Hz +/-3 dB
• Power: 300W RMS in 4 ohm, 400W RMS in 2 ohm
• Terminal connection: Gold plated bi-wiring / banana plug / pole screw
• Woofer driver: 12", acoustically transparent high flow molded aluminium basket, 100 oz magnet, rubber suspension, treated non pressed paper con , weight 6,5 kg
• Colour: High glossy black painting (genuine piano painting), Black matt painting
• General Info: RCA Stereo low level input, XLR balanced input and high level
(speaker) input
• Phase adjustment 0 to 180 degrees
• Boundary frequency control
• Volume control
• Heavy duty screw terminal gold plated connectors
• EQ-switch
• High- pass switch
• Room tuning
• Adjustable frequency
• Anti-vibration rubber feet
Configuration as tested:
Phase: 0 degrees
Tuning frequency: ~27 Hz (one port plug)
Crossover: Max
EQ: Off
High pass: Bypassed
Orientation: Woofer and ports facing the mic
http://www.dvdplaza.fi/galleria/data/954/0073.jpg
Re: Xtz 99 W12 Me
Re: Xtz 99 W12 Me
Re: Xtz 99 W12 Me
Re: Xtz 99 W12 Me
Ilkka 07-30-07 12:52 PM
Re: Xtz 99 W12 Me
russ.will 11-23-08 09:05 AM
Re: XTZ 99 W12 (maximum extension)
I see you used one bung for maximum extension. Wouldn't using both bungs to run it sealed have provided a greater maximum extension?
Just wondering, because I currently have the DSP version of this sub in my front room and with both bungs in place, room gain is resulting in a response pretty much flat to 15Hz.:blink:
Russell
oakboy37 01-31-09 12:56 PM
what do you think of it Russ?
compared to the monolith?
