-   SVSound (https://www.hometheatershack.com/forums/svsound/)
-   -   SVS SB13-Ultra Owners Thread (https://www.hometheatershack.com/forums/svsound/62888-svs-sb13-ultra-owners-thread.html)
gordog 11-01-12 10:49 AM
Noob here on HTS.
I previously owned the SVS PB10-NSD after searching for a sub that would work well for both HT and music. The much larger SVS subs simply do not fit well in my room (nor my wifeís approval), and ported subs, especially the large ones do not do as well for music. After reading that someone had replaced 2 REL Stratus subs for a PB10, I pulled the trigger on one and have been very happy since. I always wondered what I was missing in not being able to own an Ultra however, and it was with great joy that I found out SVS was finally releasing the SB13-Ultra!:sn:
My Ultra finally arrived on the 16th (2 weeks later than you fortunate Americans), and I am now a very happy camper! :T
I just posted this short review on the SVS site so I thought I'd start this thread for the other SB13-Ultra owners out there:
The build quality of the SB13-Ultra is outstanding! Looks great in the Black Oak finish and is heavier than this relatively compact box looks.
I still havenít watched a full bass-quality movie yet with my new SB13-Ultra nor have I had the chance to run REW. So far Iíve watched scenes of a few movie clips that Iím familiar with (War of the Worlds, Master & Commander, and Ironman 2) to do a quick evaluation of its abilities with just a quick set-up.
On this material, the extension, headroom, and clarity are amazing! Though I know the PB13-Ultra has more output down low, I seriously canít say I would need more than the single SB13-Ultra already provides. There are fine details heard in some bass sections and sound effects that I donít remember hearing before being presented with great definition!
Music has always been very important to me as well and is one reason that Iíve been waiting for a SB version of the Ultra. Ported subs, especially large ones, tend to do less well with music.
This is the most articulate sub Iíve ever had the pleasure to listen to! in terms of musicality, the SB13-Ultra is absolutely wonderful. On jazz, you can actually hear the sounds of a double bass playerís fingers pluck the strings, and the nuances in the way the notes are played are easily heard. Playing bass heavy music like ďWoofer CookerĒ which has serious amounts of deep bass, the SB Ultra more than stands up to the task. This sub is an out-standing subwoofer for music! I had a fellow audiophile over the other day to listen- he has a set of high-end Tetra 505 speakers and is now thinking of adding a SB13-Ultra to his system. The ultra low end bass, quickness, out-put, definition and pure musicality really blew him away.
The only thing I would suggest is that SVS throw in a small mirror as this would make it much easier to set the dial and make the adjustments after itís set in place. Even better, maybe make a way to reverse the display to use with the small hand-held mirror, however this is minor as itís still easily read. Would probably only require a small change in the display programming to accomplish.
I have no reservations recommending the SB13-Ultra for HT, and even more importantly, for music. This is a truly superb sub for both audiophiles and Home Theatre buffs.
Iím looking forward to seeing how it does after I tweak it a bit more using REW and make some adjustments with its dual band Parametric EQ.
Tallguy29 11-15-12 02:05 PM
Re: SVS SB13-Ultra Owners Thread
Thank you for this review!
Tallguy29 12-03-12 12:24 AM
1 Attachment(s)
There must be other people by now that have the SB13-Ultra and can comment about it or tested it?
I don't think I have heard any new comments or reviews on it in almost a month.
I ended up pulling the pin and bought 2 of them just in time to get pre order pricing and discount for duals. My main interest is replacing my dual ported 12" Paradigm subs as I am more interested in sound quality in music playback, I am 70/30 for Music/Movies.
I am quite impressed with the sound quality I have heard from music in comparison to my ported ones, delay is very low compared to the ported ones, also no boominess !
I have only been testing one so far in a smaller room 10'x11' with REW and hope to get them both going in living room in the next week or so to do some real testing but so far the sealed SB13 has surprised me in how low it can go even though it's only rated for 20hz and they say can go as low as 15hz in a room I guess it makes sense that in my small room it was flat to 12-13 hz! I even had to use the Room compensation mode to bring it down.
Low-pass was set to 50hz also
Ed Mullen 12-24-12 02:58 PM
Tallguy29 wrote: (Post 569190)
Because we don't high pass the SB13-Ultra on the low-end until <10 Hz, its roll-off slope is a very good complement to room gain in smaller listening spaces. Your experience in that size room is typical - extension 12-13 Hz - and that's with the room gain comp enabled!
As shown on our website Tech Specs tab, the anechoic response of the SB13U is down about 22 dB @ 12-13 Hz. So your room provides at least that much room gain at those frequencies - actually more since you have the room comp enabled. This 'free bass' allows the subwoofer to have much more extension and output than the anechoic response would otherwise suggest.
steve1616 12-25-12 10:41 PM
I love my ported PB13 Ultra. I would love to hear direct comparisons between the ported vs. sealed box. I kind of thought the ported box was the best way because I can seal it if I want to. The problem is that I always prefer the sound of the ported. I really wonder how the performance compares between the PB13 ultra with all plugs in the ports (sealed) vs. the SB 13 Ultra.
Tallguy29 12-26-12 12:00 AM
steve1616 wrote: (Post 575655)
Well Steve it is basically the same according to the testing that has been done and that I have done, if you compare the charting from the reviews on both.
I'm sure Ed can confirm this if i'm wrong.
I'm thinking a possible slight benefit going toward the low end on the SB13 being 1-2db better in the 20hz since the box is sized to be sealed vs the plugged up ports in the much bigger box.
Dale's review max Spl chart shows and I have also made my own charts and have tested one and 2 SB13's working together.
I am getting 102 db at 20hz as per what Dale's chart also shows.
I am getting a max of 111 db at 50hz which is pretty much max. (Something that no one has stated in any reviews yet)
Both subs going I have been getting 106 db at 20hz and 114.5 at 50hz
With your ports open it seems like it is a somewhat close 2 for 1 deal (2x SB13U = 1 PB13U)
I must say i did not like the sound of the new sealed subs compared to my older ported subs the first few weeks, I felt it was lacking the low end punch and thump that my ported had, mainly because the sealed were so flat and my ported subs had a boost around 26hz, but i was able to adjust things on the SB13 to give me the sound i was missing down low (higher from 28hz down) and i'll never go back to a ported again. Even if it costs almost 2x the price, They are so much cleaner, tighter, quicker, with no more boominess, delay.
Buying 2 sealed is a must though if you are use to a big ported one! :wave:
boarder1995 01-03-13 04:54 PM
I've got twin PB13 Ultras and have been mulling going to twin SB13 Ultras. I vary rarely use the max SPL my twins are capable of in my 2700cuft room, but I would much prefer the smaller size for more room placement flexibility and lower visual impact. This is a living room and my wife has been gracious with allowing the big twins thus far. I think I'll try my PB pair sealed for a while to see what I'm "missing".
i01paust 02-17-13 08:28 AM
hi, i'm new to the forum and this is my first post, not sure if my question should be placed in a new thread or in current, sorry if i did it wrong.
I just ordered my SB13-ultra last week and waiting for delivery within a couple of days. As I live in a wooden house with hardwood floor and my HT is on 3rd floor I'm thinking of adding an isolation pad under it as I expect it will add some more output than the HRS8 i currently have. The auralex subdude 15 seems like decent and cheap choice but I'm not sure if the SB13 will fit it. could anybody help me with the measures between the "feet" of the sb13? Any experience or advice on a good isolation pad for this sub (that is not a DIY)?
thanks
/Paul
whitey019 02-17-13 09:20 AM
If the feet are a problem I believe they can easily be removed. I own a SB13 Ultra and have never checked, but I've read that they have threaded inserts and unscrew.
gordog 02-17-13 10:09 AM
Congrats on your new purchase!
Though I haven't tried to unscrew the feet from my SB-13U, I remember that they were easily removed from a previous SVS so should be the same and won't be needed on your subdude 15 which should work nicely. Sorry, I just don't want to lift this beast up to do the measurement. :bigsmile:
You could always just phone SVS to ask them the distancing of the feet as well, but I suspect they will be spaced at less than 15" so won't even need removing.
