Will EQ fix subwoofer boom when seated against wall? - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 7 Old 03-08-15, 05:08 PM Thread Starter
New Member
I am running a 2.1 system in a rectangular room where the speakers are placed on the long wall and the listening position is against the opposite wall. I'm getting a lot of "boominess" unless I lean forward away from the wall.
I'm stuck with the speaker and listening position - will EQ help to improve this situation?
wixy is offline
post #2 of 7 Old 03-08-15, 05:31 PM
tonyvdb's Avatar
Tony
Re: Will EQ fix subwoofer boom when seated against wall?
Yes it can however that would mean you would loose most of the bass that you want in the room. Your better option is to get some acoustic panels/bass traps at the rear of the room behind your head.
Home theater:
Living room system:
tonyvdb is offline
post #3 of 7 Old 03-08-15, 06:36 PM
RickC
You might be able to get rid of the boom by adjusting the subwoofer to mains distance relationship or with the subwoofer phase control if it is a variable control.
Sabby is offline
post #4 of 7 Old 03-08-15, 07:14 PM
EQ will help but not fix boom
Phillips is offline
post #5 of 7 Old 03-09-15, 08:51 AM
Dwight Angus's Avatar
Dwight
It might help to move your seats away from the rear wall a few feet plus acoustic panels on rear wall.
Mains- Goldenear Triton One's
Center Channel- Goldenear Super Centre XL
Surrounds- Goldenear SuperSat 50's
Back Surrounds- Goldenear SuperSat 50c's
Atmos -4 x Goldenear HTR 7000's
Amps- Bryston 4Bsst2/Emotiva XPA-5/2 x Marantz M7025's
Processor-Marantz AV7703 Preamp
Projector- Sony VPL-HW55ES
Screen- Elunevision 140 inch 4K Audio Weave
Bluray/Universal player-OPPO 105D
Dwight Angus is offline
post #6 of 7 Old 03-09-15, 11:40 AM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
In any room with parallel dimensions there will be a “bass hole” in the dead center of the room, where bass is weak, and its intensity increases the closer to a boundary you move. So, sitting up against the wall you can expect the bass to be really strong compared to other locations in the room – you’ve experienced this phenomenon in action when you lean forward.
Since you have a sub, you can simply turn it down. If things still don’t sound right, then EQing it is recommended.
post #7 of 7 Old 03-12-15, 01:21 AM
Try not to sit at the back wall pull your couch about 2 feet away from the back wall or use bass trap at all 4 comers of your room.
b bos37 is offline
boom , eq , fix , seated , subwoofer , wall
