Behringer UCA202 - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 12 Old 09-24-18, 05:59 AM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Re: Behringer UCA202
I would expect that if the UFO is switched to Phono, then the outputs will be RIAA equalized. But not if it’s switched to Line input. This info should be in the UFO manual – if it isn’t, then only Behringer know for sure.
post #12 of 12 Old 04-22-19, 04:50 PM
blekenbleu
wtaylorbasil wrote: View Post
1. My apology. I meant UFO202 U-phono USB. It has a switch Phono/Line Input.
If the Vinyl phono jack is plugged to the input and if the switch is selected to Line, will the output signal be RIAA equalized? Or phono has to be selected for RIAA equalization?
RIAA (as well as additional gain) will be applied only when switched to Phono.
U-PHONO UFO202 User Manual
2. If I was using UCA202 U-Control Ultra low-latency 2 In/2 Out USB/Audio Interface (it has a Monitor On/Off switch) and the phono jack connected to the Input, will the output signal be RIAA equalized?
Nope, UCA202/222 does not implement RIAA. Monitor switch simply enables headphones listening to line input instead of USB output.
blekenbleu is offline
behringer , uca202
