Speaker Wiring -Will this damage my speaker - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 9 Old 07-13-13, 10:01 PM Thread Starter
phillihp23's Avatar
I temporarily wired my front height speakers to my front L and R speakers. Will this damage them?
I know this is not the correct way to wire them I am just doing it to use them while I save up for an amp.
In order to correctly install 11 speakers I need the amp to run two of them (the heights). I realize the heights will just duplicate the front L and R channels wired like this, rather than Audesey DSX separating out sound for height sound field.
Home Theater System Denon AVR4520CI, Emotiva XPA-5 Gen 2, Polk CSi A6 Center, Polk RTi A9 Front, Polk RTi A7 Front Wide, Polk RTi A1 Front Height, Polk FXi A6 Side, Polk RTi A3 Rear, SVS PB12-NSD x2 Front, SVS PC12-NSD x2 Rear, Panasonic PT-AE7000U, Visual Apex CineWhite 100" Screen, PS4, Dish Hopper, Darbee Darblet DVP 5000.My Home Theater Build
phillihp23 is offline
post #2 of 9 Old 07-13-13, 10:23 PM
HTS Reviewer
Peter Loeser's Avatar
It won't harm your speakers but your receiver's amps will see lower impedance, so be careful about playing them at high levels.
Peter Loeser is offline
post #3 of 9 Old 07-13-13, 11:28 PM
I'm assuming that you are saying you wired 2 speakers to each amp output.
If you wired them in parallel (red to red, black to black) you have significantly decreased the impedance. This will cause more current to run through your amp, which could damage it if it isn't rated for that low of impedance.
If you wired them in series (amp red to speaker 1 red, speaker 1 black to speaker 2 red, speaker 2 black to amp black) then you have doubled the impedance, which will lower the current flowing through the amp. This will certainly be safe for the amp, but you have a reduced voltage drop over each speaker, which will mean lower output volume.
If you can find the impedance rating on the amp and speaker, it will be easier to give a yes/no answer.
jimbodude is offline
post #4 of 9 Old 07-14-13, 08:34 AM
tonyvdb's Avatar
Tony
Re: Speaker Wiring -Will this damage my speaker
I would not even bother doing this until you have the correct receiver with the height channels. aside from the impedance issues, The issue I see is that your only duplicating whats playing through the mains and that will cause issues with imaging and could even cause cancellation.
Home theater:
Living room system:
tonyvdb is offline
post #5 of 9 Old 07-14-13, 08:04 PM Thread Starter
phillihp23's Avatar
Too clarify.
I wired my reciever to the front left speaker and then wired the front left speaker to the front left height speaker. Like Tony stated ^ I'm just duplicating whats playing on the front mains...
Just wanted to ensure it wouldnt damage anything.
post #6 of 9 Old 07-14-13, 10:07 PM
koyaan
Peter Loeser wrote: View Post
As Peter says, your lowering the impedence which could overload your reciever particularly at high levels. As your running Polks that are hard to drive to begin with, this is even more likely.
koyaan is offline
post #7 of 9 Old 07-15-13, 05:33 AM
tba
Or, to minimize the drop on impedance, connect (+ L) to (+ LH), (+ R) to (+RH) and (-LH) to (-RH). L and R wired normally to the amp.This is called Hafler connection and was introduced in the 80s to reach a pseudo quadrophonic environment. In this wiring, the LH will play (L-R) signal and RH will play(R-L) signal. The impedance seen by the amp is (L x (LH+RH))/(L+(LH+RH)) which is bigger than (L x LH)/(L+LH). If my lousy English was not clear, I shall try to attach a wiring drawing.
tba
tba is offline
post #8 of 9 Old 07-15-13, 12:30 PM Thread Starter
phillihp23's Avatar
Thanks for the feedback everyone. I guess I will unhook the front heights for now and just wait untill I can pick up an amp. No need to play around and take the chance of cooking my Denon receiver.
post #9 of 9 Old 07-15-13, 01:06 PM
tba
Wise choice.
tba is offline
damage , speaker , wiring
