OTA antenna and system set up - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
post #31 of 36 Old 10-18-13, 01:44 PM
Re: OTA antenna and system set up
browndk26 wrote: View Post
We got a Mohu leaf antenna today and I have been experimenting with it on our basement TV. I need to move it to an outside wall to see if I get better reception but the supplied rg59 cable is not long enough. I have some rg6 cable that I can connect it to. Will I lose much signal strength by connecting rg59 cable to rg6 cable?
Run RG6Q for total run if the cable is replaceable.
OZZIERP is offline
post #32 of 36 Old 10-20-13, 08:22 PM Thread Starter
browndk26's Avatar
I hooked up the mohu antenna in the basement again and got all the major network channels and PBS in HD and some other SD channels as well. Now to get another mohu antenna for the upstairs TV and we will be cutting the cable TV off next month. We will spend $100 on the antennas and save $70 a month.
Family Room-JVC LT-32X667, Sony BDP-S350, ATT Uverse DVR
Basement-Panasonic TC-P50X1, Sony BDP-S360, Onkyo TX-NR709, Energy C-C50, Energy C-200, Sony SA-W2500, Apple TV, WII, PS3 Super Slim, Mohu Leaf OTA
browndk26 is offline
post #33 of 36 Old 10-22-13, 03:11 PM Thread Starter
browndk26's Avatar
I have created a new macro for "mytv". I want to turn on the tv, AVR (NR-709) and then the TV/CD input. I am doing this so I can watch TV with an OTA antenna. The macro works fine to turn on everything but All Off won't turn off the TV. If I delete the macro and use the default mytv with the existing cable STB, all off turns off the TV. What have I done wrong?
post #34 of 36 Old 10-23-13, 04:17 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
Sounds like your TV has separate commands for “turn on” and “turn off.” You’ll have to program a separate “turn off” macro to power down the system.
post #35 of 36 Old 10-24-13, 04:12 PM Thread Starter
browndk26's Avatar
I called onkyo support and they helped me out. Part of the problem was I was using the component power buttons on the remote instead of the source power button. They have me use the mytv button to turn everything off. Everything works like I want it to. I may add commands later to select the TV input.
post #36 of 36 Old 12-01-13, 08:11 PM Thread Starter
browndk26's Avatar
Cancelled Uverse TV today. Going to have to get used to watching TV shows when they actually come on (no DVR). Have to get used to the home theater setup too. I will have to switch inputs on the TV when going from watching OTA TV to movies/games/apple TV. I don't think there is a way to leave the TV on one input.
antenna , ota , system
