Looking for advice on setup with difficult room (floorplan included) - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 11 Old 02-01-14, 06:13 AM
yoda13's Avatar
Yoda
Re: Looking for advice on setup with difficult room (floorplan included)
rab-byte wrote: View Post
Why not change the orientation of the room? Use the chimney as a divider and you'll have an 8'7"w X11'd space to work in. If you added an articulating mount you coul even bring the TV flush with the chimney and then your room would effectively be 14'w x9'd.
I'm liking using this wall because you have less through traffic and don't have a facing window.
I'd opt for front ported or sealed towers as your mains if you use the chimney as a room divider because of how close to the corners of the area you'll be placing them.
If you opt to move the TV out to be flush with the chimney then you could overlap the chimney with a huge screen and straddle your audio across the area.
I'd rather not use the chimney wall as the back because of how it would affect rear speaker placement.
+1
yoda13 is offline
advice , difficult , floorplan , included , room , setup
