Onkyo HT-R380 receiver w/two subwoofers - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 11 Old 03-08-14, 10:53 AM Thread Starter
Hi all, I was wondering if I'd be able to hook up two subs to my Onkyo HT-R380 receiver? I have two speakers connected to the "front speakers B" outputs in a separate floor in the house in serious need of some bass Below is a picture of the back of the receiver.
Yardley is offline
post #2 of 11 Old 03-08-14, 11:09 AM
tonyvdb's Avatar
Tony
Re: Onkyo HT-R380 receiver w/two subwoofers
As you already have two sets of speakers connected to the front speaker outputs it is going to be really hard on the amps. Connecting another sub to the receivers powered sub out will not be a good idea. Your already going to have issues with how it's hooked up now.
Home theater:
Living room system:
tonyvdb is offline
post #3 of 11 Old 03-08-14, 11:28 AM Thread Starter
tonyvdb wrote: View Post
Sorry, I guess the way I worded that is confusing. I don't have two sets of speakers connected to the front speaker outputs. Well I guess I do but I have the speakers that came with the receiver connected and an additional two speakers connected to the speakers B outputs. Why would I have trouble with this setup? Isn't that what the speaker B outputs are for? I've been using this setup for a while with no issues.
Yardley is offline
post #4 of 11 Old 03-08-14, 11:40 AM
tonyvdb's Avatar
Tony
Yardley wrote: View Post
The "B speaker outputs" essentially drops the output of the main two channels by half for each set so you will then only have half the available power for each speaker. I'm surprised you are not running into distortion issues but if it sounds good that's all the matters.
Like I said adding a second sub to the powered sup out on the receiver will drop the Ohms down way to low and essentially a short and will damage it.
Home theater:
Living room system:
tonyvdb is offline
post #5 of 11 Old 03-08-14, 11:44 AM Thread Starter
Hmm, well when I enable both A and B speakers the center speaker and surround spears are automatically disabled so I guess that compensates for the power used by the additional B speakers.
Yardley is offline
post #6 of 11 Old 03-08-14, 12:53 PM
tonyvdb's Avatar
Tony
Yes, that's very likely. The receiver you have is very low end and I would not expect it to Handel much so go easy on it and it will do just fine.
Home theater:
Living room system:
tonyvdb is offline
post #7 of 11 Old 03-08-14, 02:19 PM
eyespy39's Avatar
eyespy39
Many active subwoofers offer high level input and output. You might run your front speaker lines from your AVR into the high level input posts of such a SW and then connect the speakers to its high level output posts.
The SW filters out the low frequencies, augments them and plays them, leaving the mids and highs to the connected speakers.
eyespy39 is offline
post #8 of 11 Old 03-08-14, 04:42 PM Thread Starter
eyespy39 wrote: View Post
That sounds like a good option for me. So I would go from my AVR front speaker B L/R out into the sub and then connect the speakers directly to the sub?
Yardley is offline
post #9 of 11 Old 03-08-14, 05:28 PM Thread Starter
I found a powered sub on craigslist the back has speaker level input/output, is that the same as high level?
Yardley is offline
post #10 of 11 Old 03-08-14, 05:39 PM
tonyvdb's Avatar
Tony
Yes, that will do the job
Home theater:
Living room system:
tonyvdb is offline
htr380 , onkyo , receiver , subwoofers , w or two
