-   System Setup and Connection (https://www.hometheatershack.com/forums/system-setup-connection/)
-   -   using Bose lifestyle v30 to convert pal to ntsc (https://www.hometheatershack.com/forums/system-setup-connection/52426-using-bose-lifestyle-v30-convert-pal-ntsc.html)
yoakshay 11-27-11 01:30 PM
I have a bose lifestyle V30 which i used in the US till recently. I moved to India where the Cable STB provides an HDMI output in the PAL (50HZ) format but my Samsung LCD only supports NTSC (60HZ) format.
Is there a way for me to use the lifestyle receiver to convert the PAL input to an NTSC output without buying a converter?
Any help will be much appreciated.
Thank you,
Akshay
Mike P. 11-27-11 02:01 PM
Re: using Bose lifestyle v30 to convert pal to ntsc
From what I read it has selectable video formats, either PAL or NTSC. The product manual should state the units capabilities.
yoakshay 12-06-11 04:17 AM
hi Mike:
It has selectable formats for output but doesn't seem to have a format for inputs.
Akshay
Mike P. 12-06-11 04:42 AM
It sounds like you will need a outboard converter.
http://www.220-electronics.com/pal-n...-converter.htm
yoakshay 12-06-11 06:45 AM
Thanks Mike! since i am new to this, would you please recommend the best HDMI input to HDMI output converter. I have a 54" LED screen.
audiovideo60 12-06-11 07:12 AM
