-   System Setup and Connection (https://www.hometheatershack.com/forums/system-setup-connection/)
-   -   Help with connection types (https://www.hometheatershack.com/forums/system-setup-connection/62077-help-connection-types.html)
fviola 10-01-12 06:27 PM
My former home theater system just died..so i picked up a cheap receiver to get by for the next few months before I move..but I am having difficulty figuring out exactly what my best options are to connect this thing. Here is what I have:
1. Toshiba 40" LCD
2. Onkyo HT-S3500 5.1
3. PS3
4. Wii
4. STB - Comcast HD box
I have four HDMI cables and one digital optical cable.
My initial setup before my home theater system wasn't the greatest as the receiver didn't have many options. I connected:
PS3 -> HDTV (HDMI)
STB -> HDTV (component cable since HDMI did not produce an image when I connected the STB to the tv)
Wii -> HDTV (component cable)
HDTV -> AVR (with digital optical)
Now my new receiver has many more options for me to play around with, and I was wondering what the best possible connection will be for these different components.
I was going to connect
PS3 -> AVR (HDMI)
STB -> AVR (HDMI)
Wii -> AVR (component) And my
AVR -> HDTV (HDMI)
My questions:
1. Should I scrap the digital optical all together? The PS3, STB, AVR, and HDTV all support the digital optical, but is it necessary to use?
2. Is using an all HDMI setup going to produce the best results?
3. If I connect the Wii using component, will anything be distorted when the image is passed through an HDMI to my HDTV?
Any suggestions will be greatly appreciated.
I should also note: I am probably going to use my AVR for all audio. I do not necessarily need my HDTV to produce sound without the AVR turned on. But if it is easy to do so, I will.
86eldel68-deactivated 10-01-12 08:33 PM
Re: Help with connection types
According to the product page, the AVR that comes with your HTiB decodes lossless audio (Dolby TrueHD and DTS-HD MA), so connect all your components to your AVR, and run a single connection from your AVR to your TV.
If you do it the other way 'round - components to TV, optical from TV to AVR - you'll only get whatever audio your TV sends to the optical output (up to a maximum of DD5.1 and DTS5.1).
The owner's manual for the AVR will tell you whether it will transcode component video to HDMI. If it doesn't, you'll need to run a separate component connection from your AVR to your TV for your Wii.
fviola 10-01-12 08:42 PM
Thanks for the reply
fviola 10-01-12 08:44 PM
86eldel68-deactivated 10-01-12 08:48 PM
What I am asking is, should I even bother with digital optical or is using HDMI the best way?
Don't use optical if you can avoid it because optical doesn't carry lossless audio.
And if I connect something, say a Wii, to my AVR using a component cable..and connect the AVR to my tv with an HDMI, is anything lost in thee signa as it goes from one type of connection to another?
Nothing would be lost if your AVR transcodes component to HDMI. I just had a look at the manual (PDF) and it says that it doesn't (pg. 59). So if you're connecting your Wii to your AVR using a component cable (see pg. 39 re. assigning a component video input) plus an optical cable for audio, you will need to run a component cable from your AVR to your TV for the Wii's video stream. (The Wii's audio stream will be switched to the AVR's HDMI output - see pg. 59.)
fviola 10-01-12 08:51 PM
Awesome.
Thanks a lot for your response. I will be sure to use HDMI for everything...except for the Wii as you mentioned.
Thanks again..very helpful.
86eldel68-deactivated 10-01-12 08:51 PM
Glad to help. :)
hjones4841 10-02-12 03:38 AM
eljay wrote: (Post 552815)
I thought the optical out of a TV only was for digital TV channels and that it did not output 5.1 for other sources connected to it.
86eldel68-deactivated 10-02-12 06:53 AM
I'm not sure what gets output by a particular TV's optical digital output, but because it's an optical digital connection he won't get more than lossy 5.1. Which is why I said "you'll only get whatever audio your TV sends to the optical output (up to a maximum of DD5.1 and DTS5.1)." :)
fviola 10-04-12 06:43 PM
I need some more help with my Onkyo HT-S3500 5.1.
I bolded the areas where my main concerns are.
I am trying to figure out the best listening modes for this device
Everything I am using is connected through HDMI.
My Listening mode on my PS3 reads as: MULTICH
Am I to assume that MULTICH means that my audio will be output whatever format my PS3 is recoginizing? Cause usually the receiver would display this information, but I guess the PS3 is deciding what the output is and then it is simply labeled as MULTICH. Is this correct?
Cause I am watching The Avengers on Blu Ray. When I check the audio output on my PS3, it says:
DTS-HD MA 7.1
But on my menu for listening modes on my receiver it reads as: MULTICH
Also, when watching TV from my Cable/Sat box, the Listening Mode reads as Dolby. Is this the best a Cable/Sat will output audio? Cause I don't have any other options other than Dolby.
And just to clarify, my receiver's listening modes are listed as being cable of producing DD,DD+,DD TrueHD,DTS, DTS-HD High, DTS-HD MA, and so on...
