Static problem on Lp's - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 16 Old 09-27-15, 07:13 PM Thread Starter
tcarcio's Avatar
TC
How do any of you solve this problem? I have the AudioQuest brush but it actually makes the problem worse sometimes. I am sure that is does so because it isn't grounded. There are some solutions out there like anti static sleeves and anti static guns but I want to know what you guy's use and if you could post any links to products you have tried and find work really well. Also do any of you use this, http://www.sleevecityusa.com/GroOove...p/gem-lube.htm I read that it helps keep records from getting static in the first place but I dont know anyone that actually uses it. I am just getting back into vinyl and would rather buy products that are tested by people like you that I know here at HTS can be trusted. Any help or advice on the subject would be appreciated, Thanks, TC.
Onkyo TX-NR809 HT receiver
HPS-4000,SR-70, John Allen, Klipsch Heresy, Speakers for L.C.R.
QSC GX-5 power amp for L+R mains
Chase Home Theater PRO-10's for surrounds
Behringer EP 4000 pro amp for the Danley DTS-10 tapped horn sub
Oppo BDP-93 universal BD player
Toshiba HD XA2 HD dvd player
Sony VW-VPLPRO1 1080p PJ
Cinema White 1.0 gain 106" fixed frame screen
Dish network with 2 Hoppers and 1 Joey
tcarcio is offline
post #2 of 16 Old 09-27-15, 07:20 PM
ellisr63's Avatar
Ron
Re: Static problem on Lp's
Years ago I had 2 different zapper guns (one was a Zerostat as I recall) that I used on my records, and then would clean them on my Nitty Gritty record cleaning machine. After this I would put them in the Discwasher brand sleeves. When I pulled them out I would zap them, and clean them with a record cleaning brush once again. Not sure if I got the order correct as it has been 20 years, but it worked, and I had zero pops or noise playing my records. I hope this helps you.
My Home Living room Theater
Samsung 65" FP, Yamaha CX-A5100, Xilica XP4080, (4) Klipsch RP160MS, (4) JBL 8340As, (2) Yamaha P2500s amps, PS3, XBox One, (1) Asus mini pc, (2) Furman Power Conditioners, Darbee Darcet, and a Project RPM 1.5 Carbon turntable..
ellisr63 is offline
post #3 of 16 Old 09-27-15, 07:50 PM Thread Starter
tcarcio's Avatar
TC
ellisr63 wrote: View Post
I did see this one, http://www.google.com/aclk?sa=l&ai=C...sichallGZ3.htm but I thought it a bit pricey. If it really does the job then it may be worth the money. I also thought of trying to put a ground wire on the AQ brush I have and grounding it to the TT but if they sell one like that already, depending on the price, that could be an option. Thanks for the advice. Any more products people can recommend.
tcarcio is offline
post #4 of 16 Old 09-27-15, 10:31 PM
thrillcat's Avatar
Pfanstiehl Pfan-Stat LP Vinyl Record Album Anti-Static Cleaner, 4 oz Spray https://www.amazon.com/dp/B00W223NGC..._2rlcwbV8T1M9T
Sent from my iPhone using Tapatalk
thrillcat is offline
post #5 of 16 Old 09-28-15, 07:32 AM Thread Starter
tcarcio's Avatar
TC
thrillcat wrote: View Post
I couldn't find any user reviews on that product but I did find it on ebay for allot cheaper than what Amazon sells it for. I wonder why such a price difference??? http://www.ebay.com/itm/VINYL-RECORD...3D271622763973
tcarcio is offline
post #6 of 16 Old 09-28-15, 12:29 PM
thrillcat's Avatar
Yeah, I think I ordered it from eBay, or it was at least cheaper on Amazon when I did order it last. A bottle lasts a long time, about two quick sprays per side and wipe it down with a brush. Does some basic cleaning (good for light dust, nothing deep, though) but completely kills static pops. I've been using it for 4 or 5 years now.
post #7 of 16 Old 09-28-15, 12:37 PM
ellisr63's Avatar
Ron
tcarcio wrote: View Post
Iif you look around you can find a used one or a B-Stock and save some money.
ellisr63 is offline
post #8 of 16 Old 09-28-15, 01:54 PM Thread Starter
tcarcio's Avatar
TC
Well for the price on Ebay I should give it a try.....
I will keep my eyes open for a better deal.....
tcarcio is offline
post #9 of 16 Old 09-30-15, 07:34 PM
slovell's Avatar
Sam Lovell
I've got a Discwasher Anti-Stat Mat that I bought back in the early eighties that works like a champ to this day. No static at all (FM) on my records, but they haven't sold them for years. I guess if you sell a product that lasts forever it might not be a very good business model.
Panasonic TC-P55 VT60
Marantz AV-7005, UD-5007
Adcom GFA-5500, GFA-7000
Jolida JD-100A CDP, JD9A phono stage
VPI Scout with ATOC9 MKII LOMC
Matrix M-Stage, Little Dot MKII headphone amps
Klipsch KLF-20s modded with Crites titanium diaphragms & crossovers
Klipsch KV-4 center, KSF-S5 & SS-1 surrounds
Hsu VTF-3 MK4 sub
Dynaco ST-70 clone tube amp
slovell is offline
post #10 of 16 Old 09-30-15, 07:37 PM
thrillcat's Avatar
I guess I should add that I'm using a suede mat under my records in addition to the pfan-stat.
lp , problem , static
