Klein's Software Update Released - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 8 Old 06-23-15, 05:53 PM Thread Starter
ConnecTED's Avatar
Klein ChromaSurf 5.23.532 (23 June 2015)
Release Notes
VerfiyBlack: aiming lights check
WhiteOffSets: Changed "Sony" to "Sony OLED"
Flicker: Added Colorimeter connection options
Gamutspec: Changed tolerance for white offsets
MainWindow: users can click on Flicker before Klein device is hooked up
MainWindow: Fixed an xy issue on Magnified mode
MainWindow: Add offsets settings
MainWindow: CalFil 0 will display on startup
CreateCal: Fixed crash on Switching devices
CreateCal: Fixed bug on closing form and close Klein Device
CreateCal: Fixed bug on getting measurements from Klein Device
Download Link
Software: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
Video Processors: eeColor 3D LUT Box, Darbee DVP-5000 - Pattern Generator: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1Display PRO, Chroma 5 PRO
ConnecTED is offline
post #2 of 8 Old 12-17-15, 04:49 AM Thread Starter
ConnecTED's Avatar
Re: Klein's Software Update Released
Klein ChromaSurf 5.36.551 (16 December 2015)
Release Notes
Mac: Fixed a connection bug
Mac: Fixed a saving profile bug
Mac: Fixed a QC profiling bug
Gamutspec: Fixed DCI-P3 White point
Gamutspec: Fixed offset not applying on startup
Mainform: Fixed an averaging display bug
FlickerForm: Fixed the signal graph when no K-10 is hooked up
CreateCal: Updated the PatternManager
PatternManager: Changed the UI
Themes: Fixed a few issues
Download Link
post #3 of 8 Old 12-17-15, 05:09 AM Thread Starter
ConnecTED's Avatar
Note: Download Link for Windows Installation is temporary broken, I will update again when it's been fixed.
post #4 of 8 Old 12-17-15, 01:31 PM Thread Starter
ConnecTED's Avatar
Download Link for Windows Installer is now working.
post #5 of 8 Old 02-18-16, 05:09 AM Thread Starter
ConnecTED's Avatar
Klein ChromaSurf 5.37.557 (17 February 2016)
Release Notes
CreatCal: Fix couldn't read measurements from CS-2000, PR-650, and BM-7
Download Link
post #6 of 8 Old 01-07-17, 02:46 AM Thread Starter
ConnecTED's Avatar
Klein ChromaSurf 5.43 (04 January 2017)
New Features
Test Color Batch allows users to set up color patch timelines.
Profile selection for CS.
Arrow keys now navigate between colors on Pattern Gen Window.
Added the resolution of the Patch Sizes on Pattern Gen Window.
Faster way to check Klein devices.
Faster way to check for PR-650 devices.
Faster way to check for CS-2000 devices.
HI-DPI buttons.
Antialiasing on Graph.
Updated the UI for Flicker and Main Forms.
Added Max averaging for auto low light.
Added auto for low light for averaging on Pattern Gen Window.
Added Faster Measuring Mode.
Allow users to log more than one time in Flicker log.
Kelvin Calculator can convert from LAB to any other measurement by using spectro.
Added loading iris when doing black calibrations.
Flicker Auto lock.
Deleting profiles requires password.
Crash Fixes
Sending images without a Pattern Gen hooked up.
Mac: selecting a device.
Mac: rescanning for a device.
Clicking QC save data when there isn't any data.
Bug Fixes
Labels and LineEdits able to resize better.
Changed nits to Lux when using Lux profiles.
Memory leaks.
Kelvin Calculator graph now updates on a gamut change.
Better locking for Mac.
Using RAW XYZ instead of corrected XYZ for averaging.
Units in Manual Entry.
Download Link
post #7 of 8 Old 08-19-17, 04:57 AM Thread Starter
ConnecTED's Avatar
Klein ChromaSurf 5.50 (18 August 2017)
Bug Fixes
Mac crash bug fixed.
Various spelling fixes.
Download Link
post #8 of 8 Old 11-02-17, 08:25 AM Thread Starter
ConnecTED's Avatar
Klein ChromaSurf 5.53 (01 November 2017)
Bug Fixes
Flicker Form reset workspace on opening.
Updated copyright year.
Autoconnect to last Klein device on startup.
Fixed smoothing.
Fixed first Hz value.
Download Link
klein , released , software , update
