Calibration settings for LG 55uf6450 - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 14 Old 10-14-15, 12:16 PM Thread Starter
miguel vigo
Hey guys, does anyone has the calibration settings for LG 55uf6450?
mvigo is offline
post #2 of 14 Old 10-23-15, 10:39 AM
Lumen's Avatar
Lou
Re: Calibration settings for LG 55uf6450
This set is so new I was unable to find a professional review which divulges the optimal settings. If you're unable to find one as well, then I'd suggest using a calibration disk like the ones described here.
I try to be as good as my dog thinks I am
Lumen is offline
post #3 of 14 Old 10-29-15, 12:59 PM Thread Starter
miguel vigo
Lumen wrote: View Post
Thanks for the response, just received the Disney W.O.W. disc. planned to calibrate the tv this weekend. Which mode setting I should use? (vivid, cinema, user, standard etc...)
mvigo is offline
post #4 of 14 Old 10-29-15, 03:56 PM
Lumen's Avatar
Lou
It doesn't matter too much which mode you start with (except that you may be further away from where you'll end up). It also depends on the TV because there's no standard calibration for those modes. I would start with "user" so that you can return to the others for reference or for fun. The Disney disk holds its own against others of its type, and I think you'll be very pleased with the results. In case they don't tell you, set your lighting to be the same as that under which you view movies.
Sent from my iPhone using Tapatalk
Lumen is offline
post #5 of 14 Old 10-29-15, 05:04 PM
Plain ole user
lcaillo's Avatar
Tech Guru
One place to start is tweaktv.com.
lcaillo is offline
post #6 of 14 Old 11-05-15, 02:23 PM Thread Starter
miguel vigo
Okay I calibrated the tv with the disc, I'm having a hard time setting the backlight. Just don't know which is the correct setting and how i would know is the backlight is correct?
mvigo is offline
post #7 of 14 Old 11-06-15, 01:57 PM
Lumen's Avatar
Lou
If there's no instruction or calibration on the disc itself, check to see if anything is mentioned in the disc's user manual. If not, or if no manual, then the following advice from this setup article should work:
"For critical viewing, or watching at night, the idea is to get the best black levels, while still creating a watchable image. Once the you set contrast and brightness correctly, turn the backlight control all the way down. This will likely be too dark for most viewing. Turn it up to the point where it looks the best."
Lumen is offline
post #8 of 14 Old 11-06-15, 02:01 PM
Lumen's Avatar
Lou
lcaillo wrote: View Post
mvigo wrote: View Post
Another option... did you try Leonard's suggestion above for TweakTV?
Lumen is offline
post #9 of 14 Old 11-11-15, 02:17 PM Thread Starter
miguel vigo
Yes I did tried Leonard option but they don't have that model. But I did tried using the Disney W.O.W disc, it did helped. But I think I should go with a professional calibrator. What do you think? I'm wandering is there a difference calibrating a 1080p tv and a 4k tv?
mvigo is offline
post #10 of 14 Old 11-11-15, 03:07 PM
Lumen's Avatar
Lou
Go with a professional calibration if you don't mind paying for one., or if you're one of those people (like me) that just needs to know it's right. I'm afraid this is taking us out of my knowledge comfort zone, so I hope someone with more experience will comment.
Lumen is offline
55uf6450 , calibration , lg , settings
