Free calman colorchecker software !!! - Page 8 - Home Theater Forum and Systems - HomeTheaterShack.com
post #71 of 75 Old 06-09-17, 03:18 AM
ConnecTED's Avatar
Re: Free calman colorchecker software !!!
CalMAN 2017 5.8.1 Open Beta - Build: 16 Released @ 8 June 2017
Important Note!
The below warning does not apply to anyone who is upgrading from Beta 1 (5.8.1.8 ). Deactivating CalMAN is not necessary in this situation.
All users must deactivate the license on their current CalMAN build before updating to the new release.
All users must license their CalMAN build after installation with their CalMAN License ID and License Password.
Changes to the License Manager means that your machine ID will change. If you do not deactivate CalMAN before you install this new build, CalMAN will no longer be licensed and you will have no activations available in order to reactivate.
If you find yourself in this situation, please contact [email protected] or [email protected] and we will be able to help you get that straightened out.
You must have an available deactivation in order for this process to work correctly. If you do not, please contact [email protected] or [email protected] and we will be able to assist you.
You will need your License Activation ID and Activation Password in order to activate CalMAN again. If you do not have this information, it can be retrieved from the customer portal at https://aquaman.portrait.com/custome...thorID=2451871. If you do not have your login information, you can use the "Forgot your password?" link to retrieve it. If this does not work, please contact Support or Customer Service for assistance before you upgrade.
Download Links:
Business - http://files.spectracal.com/download...N_Business.exe
Home Theater - http://files.spectracal.com/download...alMAN_Home.exe
Studio - http://files.spectracal.com/download...MAN_Studio.exe
RGB - http://files.spectracal.com/download...N_RGB_Only.exe
Beta Release Notes
Resolved the licensing issues when upgrading from CalMAN 2016 R2 (5.7.2.61).
Added support for the Datacolor Spyder 5 meter. (Ultimate, Professional, Expert, ISF, Studio, Enthusiast, Control)
Added support for the AccuPel DGA-6000 pattern generator. (Ultimate, Professional, Expert, ISF, Studio, ColorMatch, Enthusiast)
SDR calibration support for the Panasonic 2017 EZxxx Series OLED. (Ultimate, Professional, Expert, ISF, Studio, Enthusiast, Control)
SDR calibration for the Samsung 2017 QLED models has been extended to additional license levels. (Ultimate, Professional, Expert, ISF, Studio, Enthusiast, Control)
Added the HLG Calibration workflow. (Ultimate, Professional, Expert, ISF, Studio, Enthusiast)
Color Volume Workflow has been added to the Home Theater installer.
Known Issues
HDR and HLG calibrations are still a work in progress for the above mentioned Panasonic and Samsung displays.
For the Panasonic 2017 models, when you select the Color Temp option of Warm 2 in the DDC controls, the drop down changes to Warm 1. The display is set to Temp 2 however.
Software: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
Video Processors: eeColor 3D LUT Box, Darbee DVP-5000 - Pattern Generator: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1Display PRO, Chroma 5 PRO
ConnecTED is offline
post #72 of 75 Old 07-02-17, 06:07 AM
ConnecTED's Avatar
CalMAN 2017 5.8.1 Open Beta 3 - Build: 26 Released @ 28 June 2017
Download Links
Note:
CalMAN 2017 requires updated maintenance as of June 2016.
Important: There is a known issue where the All Access\Maintenance installer check during an upgrade is incorrectly identified as being valid. In this situation the installer will say the license is valid for the upgrade, but ultimately the build will fail to license.
If you continue with the installation and find yourself in a situation where you cannot license, go into Licensing, click the Deactivate button, uninstall beta 3 and roll back to a previous version.
As mentioned above, Maintenance will need to have been purchased June 2016 or later in order for your license key to be good with CalMAN 2017.
Additional license manager/machine ID fixes. There have been a few licensing manager fixes applied in the 2017 Beta releases. For users limited to CalMAN 2016 R2 release and do not not have a the ability to update to 2017, the License Manager fixes are planned to be provided in a CalMAN 2016 R3 patch release.
In prep for the CalMAN 2017 release, This installer will deactivate CalMAN. CalMAN will need to be reactivated upon first launch. A few weeks ago, everyone's accounts were set to 10 deactivations.
Release Notes
CalMAN now supports HDR10 and HLG calibrations on the Panasonic 2017 EZxxx Series displays. Pattern insertion is recommended for HDR calibration (5 second interval, 5 sec duration, 0% level) this prevents the panel from overheating during sustained Bright patches.
Added support for the new Dolby Vision Custom workflow. (Licenses: Ultimate, Professional, Expert, Studio, Enthusiast)
The new Dolby Vision Custom calibration workflow/process for displays that support a custom Dolby Vision Configuration File is now enabled in CalMAN. Currently the only TV to support this is the 2017 LG OLED. The process requires a pattern generator that supports Dolby Vision metadata.
CalMAN uses a new type of Dolby Vision metadata to put the color volume mapping engine into bypass mode. CalMAN then calibrates the display and generates a new Dolby Vision configuration file that is loaded into the supported TV via USB stick.
Resolved an issue with the Radiance Pro where the wrong LUT could get assigned to the pattern generator.
Resolved an issue on the Panasonic 2017 EZxxx Series displays where the Color temperature DDC control would stay at Warm2 when selected.
Resolved an issue where CalMAN would display an inaccurate error message which attempting to connect to the Murideo 6G.
Resolved an issue with LUT file formatting for OSEE displays.
post #73 of 75 Old 07-06-17, 05:01 PM
ConnecTED's Avatar
CalMAN 2017 5.8.1 RC1 - Released @ 07 July 2017
New Features
Auto Calibration for Samsung 2017 QLED televisions.
Auto Calibration for Panasonic 2017 EZxxx series OLED televisions.
New Color Volume Workflow allows you to quickly measure the color volume of any display.
New Color Volume Visualizer - three-dimensional graphing engine that displays the measurements of the Color Volume Workflow. To access, follow the link in the Color Volume Workflow
New HLG Workflow support for the hybrid log gamma version of high dynamic range that is rapidly gaining acceptance for live video production
New Dolby Vision Custom Workflow adds support for displays that support the new Dolby Vision Configuration File. CalMAN uses a new type of Dolby Vision metadata to put the color volume mapping engine into bypass mode. CalMAN then calibrates the display and generates a new Dolby Vision configuration file that is loaded into the supported TV via USB stick.
New Broadcast Monitor Workflow
New Hardware Support
SpectraCal VideoForge Pro 4K HDR pattern generator
Photo Research PR653 spectroradiometer
UPRtek MK550T spectroradiometer
Datacolor Sypder 5 colorimeter
Improved Hardware Support
New display type characterizations for SpectraCal C6: Projector (Laser Phosphor), Projector (Laser Phosphor) - Panasonic RZ12K, Projector (Laser Phosphor) - Panasonic RZ970
Added 4-40 Pattern Support (4% window, 40% background) Added to VideoForge HDMI, Murideo SIX-G, Quantum Data 780, 804, 804A, Astro.
Enhanced Capabilities added to Murideo SIX-G: Changed default output to be YCbCr, Added resolution drop down, Added FW check. V1 of the Muridio 6G will need to be the following FW versions, 6G v2 - 2.40, 6G v1 - 1.87
Added support for SDR calibrations for 2017 Samsung models.
HDR Auto Cal is WIP. Beta accuracy levels are not an indication of Release HDR AutoCal accuracy levels.
Resolved Issue
Resolved an issue with meter profiling.
Resolved an issue when disconnecting from the Murideo Prisma as a Display.
Resolved an issue which would cause CalMAN to improperly identify an x-rite OEM i1Pro2 as an i1Monitor.
Known Issues
Color Volume Workflow - LAB Absolute selection reports LAB Relative results
Download Links
post #74 of 75 Old 07-24-17, 05:55 PM
ConnecTED's Avatar
CalMAN 2017 5.8.1 Final (Build 34) Released @ 25 July 2017
Release Notes
This is the exact same build as CalMAN 2017 5.8.1.34 (Build 34) RC3. There have been no changes.
Download Links
post #75 of 75 Old 08-03-17, 02:48 AM
ConnecTED's Avatar
CalMAN 2017 5.8.1a Final (Build 37) Released @ 03 August 2017
Release Notes
Added EDRs for the SpectraCal C6 for the 2015, 2016, and 2017 Samsung QLED displays.
Minor text change on the Color Volume Analysis workflow.
Resolved issue bringing up specialty patterns on the SpectraCal VideoForge Pro.
Download Links
calman , colochecker , free , software
