Ted's LightSpace CMS Calibration Disk - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
 1Likes
post #11 of 27 Old 10-13-14, 07:21 PM Thread Starter
ConnecTED's Avatar
Re: Ted's LightSpace CMS Calibration Disk
New Free CalMAN 5 Workflow (For Ted's Lightspace CMS Calibration Disk Users) Released!
I have just send to all Ted's LightSpace CMS Calibration Disk users a new workflow to improve further their measuring/reporting experience.
This new workflow has been designed for Reporting of Pre/Post-Calibration Results Tool for Professional Calibrators but for DIY/ Calibration Enthusiast users also.
Color Comparator Comparisons Workflow has created based to an idea of a simple and 'customer friendly & easy to understand' way of reporting.
It's a better way of presenting the Pre/Post-Calibration Results with Charts that are easier to understood by people not involved in calibration.
The Pre/Post-Calibration Charts features only the required and most important measurement numbers.
Color Comparator Pre-Post Calibration Comparisons has been designed for easier visual notice of the post-calibration improvement and it's very helpful from customers to understand the difference of the measured colors of their just-calibrated display versus the reference video performance 'look-like' using the 8-bit RGB Triplet color differences that color comparator is based.
Bellow you can find some layout pages screenshots, the full workflow layout page screenshots are available @ CalMAN 5 Workflows for Ted's LightSpace CMS Calibration for Disk Users webpage.
Software: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
Video Processors: eeColor 3D LUT Box, Darbee DVP-5000 - Pattern Generator: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1Display PRO, Chroma 5 PRO
ConnecTED is offline
post #12 of 27 Old 10-18-14, 02:11 AM Thread Starter
ConnecTED's Avatar
DVDO's AVLab TPG 4K Reference Pattern Generator has added a new and very useful feature that is called 'Color Checker'. Using that feature it can display digital value for selected pixel from it's HDMI Input.
Here is an example, the 8dr means "8 bit, decimal, RGB" then the values are the RGB values of the pixel that the cursor is pointing to.
Pressing the left/right TPG buttons changes decimal to hex. It will read RGB/YC, 8/10/12 bit values.
"Cursor" is moveable around the screen using DVDO's remote.
A professional calibrator from using Ted's LightSpace CMS Calibration Disk has tested yesterday the accuracy of the encoded chapters of the disk using that AVLab TPG's color checker function.
He measured 100% Saturation and 100% Luminance RGBCMY Patterns, Color Checker patterns and Near-Black Patterns of the CalMAN section of the disk.
He found that the Ted's LightSpace CMS Calibration Disk has been encoded properly and every single bit is on it's reference position.
Below you can find his results:
This means that Ted's LightSpace CMS Calibration Disk can be used from DVDO's AVLab TPG 4K Reference Pattern Generator users as a reference and now they can able to check any Blu-Ray Player / Media Player Output accuracy and detect digital errors that wrong player settings can introduce.
Mede8er MED800x3D and eGreat R6S Media Players used as a source for that test. Both made no digital errors on HDMI output.
Here is the link of the full review and procedure details that the professional calibrator from Poland has used for this test.
post #13 of 27 Old 10-21-14, 11:27 AM Thread Starter
ConnecTED's Avatar
Batch Files Version 1.3 for CalMAN 5 Automated Measurements has been released today.
Version 1.3 adds support for the required measurements using the CalMAN 5 Color Comparator Comparisons Workflow for Ted's LightSpace CMS Calibration for Disk Users.
These are the new Automated Measurement options:
4-Point Saturation (for Color Comparator Comparisons Workflow)
5-Point Saturation (for Color Comparator Comparisons Workflow)
4-Point Luminance (for Color Comparator Comparisons Workflow)
5-Point Luminance (for Color Comparator Comparisons Workflow)
For ColorChecker Classic / SG / SG Fleshtones measurements, you can use the 13,14,15 selections for Color Comparator Comparisons or Verify Calibration Tools Workflow also.
Ted's LightSpace CMS Calibration Disk users have automatically received the email with download link and instructions before some minutes.
post #14 of 27 Old 10-29-14, 04:06 PM Thread Starter
ConnecTED's Avatar
CalMAN Color Comparator Comparisons 1.0.1 Workflow for Ted's Lightspace CMS Calibration Disk Users had been released.
I have just send to all Ted's LightSpace CMS Calibration Disk users a new version of CalMAN 5 Color Comparator Comparisons Workflow.
Changes
Fixed a scaling problem of Pre-Calibration Comparator dE numbers datagrid of Grayscale & ColorChecker SG Skintones Comparator Comparisons layout pages where the dE numbers where not displayed correctly only in case where the display performance has dE numbers above 9.99dE.
The contrast ratio data field is now wider to be able to display without problems large contrast ratio numbers.
Notes
The Color Comparator Comparisons Workflow has created to be used mainly for field calibrators/DIYer's to showcase their pre/post calibration results to customers/people with limited calibration experience.
Pre/Post-Calibration dE numbers & CIE Charts are not 'customer friendly' and it's difficult from them to to understand what is really happening by looking at them.
Color Comparator Pre-Post Calibration Comparisons color screens it's a great tool for easier visual notice of the differences using the 8-bit RGB Triplet color differences.
Example of Use
Bellow you can find some pre-post calibration screenshots by using Color Comparator Workflow in action.
The display used for that example was a Samsung 60H7000 using the available internal display controls.
All the required patterns for pre-calibration - post evaluation and measurements came from Ted's LightSpace CMS Calibration Disk.
All the measurement patterns were generated from the disk, using CalMAN's Automated Measurement Utility 1.3. which automatically displays (per 2 seconds) and measures each color patch without user prompt. I used a Klein K-10A profiled from JETI 1211.
I used 75% Saturation with 100% Stimulus patterns for CMS calibration.
Pre-Calibration Reports shows performance of Samsung 60H7000 @ Natural mode, since it has the only mode that was used from the user of this display since now.
Post-Calibration report shows the performance of ISF-Night calibrated memory.
11-Point GrayScale (Pre-Calibration)
11-Point GrayScale (Post-Calibration)
4-Step Saturation (Pre-Calibration)
4-Step Saturation (Post-Calibration)
ColorChecker Classic (Pre-Calibration)
ColorChecker Classic (Post-Calibration)
ColorChecker SG Fleshtones (Pre-Calibration)
ColorChecker SG Fleshtones (Post-Calibration)
...and now the Color Comparator Comparisons Screens ...how dE patch color differences are visible or not using CalMAN's Comparator feature:
11-Point Grayscale Color Comparator Comparison of Pre/Post Calibration
4-Step Saturation Color Comparator Comparison of Pre/Post Calibration
ColorChecker Classic Color Comparator Comparison of Pre/Post Calibration
ColorChecker SG Fleshtones Color Comparator Comparison of Pre/Post Calibration
post #15 of 27 Old 12-27-14, 03:16 PM Thread Starter
ConnecTED's Avatar
CalMAN 5 Pre-Calibration Tools 1.1.2 Workflow for Ted's Lightspace CMS Calibration Disk Users has just released.
I have just send to all Ted's LightSpace CMS Calibration Disk users a new version of CalMAN 5 Pre-Calibration Tools 1.1.2 Workflow.
This is a free workflow update for Blu-Ray Disk Copy, Blu-Ray ISO Digital Download or Media Files Digital Download users.
Notes
This version adds some info's to layout pages for better display overview for more simple to use calibration time.
Added separate layout pages for Color Gamut Calibration 100% SAT / 100% STIM, 100% SAT / 75% STIM, 75% SAT / 75% STIM, so now it's quick to change and overview the differences very fast by calibrating different Saturation/Stimulus Levels. It doesn't require any change of CalMAN Settings anymore.
As you know, when you want to perform Color Gamut Calibration with 75% Saturation, you have to change the Slider manually to see each color, there 7 selectable sliders for this. I have added all Saturation Colors in one Slider and you can now select any color of interest very quick. This saves some time.
Added Color Checker Classic Layout page, that is helpful to find and select the most accurate initial display mode to start with. Here you can change that Layout Page to ColorCheck SkinTones via CalMAN's Settings for tweaking the Samsung's Skin Tone Setting.
Changes
Meter Profiling Check Layout Page: Added a datatable with xyY values for WRGB for the Reference / Profiled meter in case that the user want to copy the values and used them to 3rd party software solutions, like ChromaPure, LightSpace, Klein ChromaSurf; to measure with CalMAN and later create a meter correction table with these values using other software; to use the same table everywhere. It's helpful for those who want to create meter correction table for Klein, to quick copy-paste the values of the Reference Meter and paste them to Klein's ChromaSurf. You can copy any x,y,Y number using right mouse click & copy.
x-Point Grayscale + Gamut Layout Page: Added info for Black Level Luminance, added Grayscale's Red/Green/Blue Color Channel Balance (Average) info, added selector for quick change of Grayscale Points that the user want to measure; to quick change from 11 to 21 Point Grayscale very quick without touching the CalMAN's Settings.
x-Point Saturation Layout Page: Added selector for quick change of Saturation Points that the user want to measure; to quick change from 4 to 5 or 10 Point Saturation very quick without touching the CalMAN's Settings.
x-Point RGB Balance Layout Pages: Added button for Read Continuous and Meter Stop, for users that want to perform quick/continuous 2/3/4-Point RGB Balance for displays with DDC or while they are changing values from the OSD menu, for displays where the OSD menu appearance is not affecting calibration measurements.
11/21-Point Grayscale Layout Page: Added info for Black Level Luminance, added Grayscale's Red/Green/Blue Color Channel Balance (Average) info, added selector for quick change of Grayscale Points that the user want to measure; to quick change from 11 to 21 Point Grayscale very quick without touching the CalMAN's Settings.
post #16 of 27 Old 01-08-15, 06:29 AM Thread Starter
ConnecTED's Avatar
Tip For CalMAN 5 Users
For the users that are using the Ted's CalMAN 5 Workflows, as you probably have seen, there is not available at any layout page the ReadAll button, since all workflow have been configured to work with Singe Read with AutoAdvance.
For the users that can use the CalMAN Workflow Design feature, there is no need to enter to design mode to add manually a ReadAll button, they can use the CalMAN's Keyboard Shortcut for that.
Before that, the users have to enable the Keyboard Shortcuts feature from CalMAN's Application Preferences and after than they can simply press F10 key which is the keyboard shortcut key for ReadAll at any CalMAN layout page.
This is helpful for users that are using Ted's CalMAN Workflows with External Hardware Pattern Generators or with CalMAN's Internal Pattern Generator.
post #17 of 27 Old 01-29-15, 11:57 AM Thread Starter
ConnecTED's Avatar
CalMAN's Grayscale vs. ColorCheckerClassic/SG Measuring Tip
I have been questioned by disk users that have calibrated their displays using 11/21-Point Grayscale Chapters of the disk why later during their verification measurement run using ColorCheckerClassic/SG chapters, they see larger dE errors at Gray measurements of ColorChecker Classic/SG while by measuring the same named patches using the x-Point Grayscale Chapter they see lower dE numbers there.
This is not a disk encoding problem, it's happening because the Gray Levels of ColorChecher are not matching the levels of Grayscale patches.
There are the exact levels:
Gray 35 of ColorCheckerClassic / SG means 62% Greyscale.
Gray 50 of ColorCheckerClassic / SG means 73% Greyscale.
Gray 65 of ColorCheckerClassic / SG means 82% Greyscale.
Gray 80 of ColorCheckerClassic / SG means 90% Greyscale.
CalMAN's ColorChecker is based to the names & colors of the Macbeth's ColorChecker which was a printed cart with 24 colors that used for years for many different proposes.
Gray/Neutral patches represent the different lighting conditions at Macbeth's ColorChecker.
SpectraCAL's Developer mapped these targets to RGB space and kept the original names except the grey patches which are named as Neutral 3.5, Neutral 5.0, Neutral 6.5, Neutral 8.0 at original ColorChecker....SpectraCAL's Developer renamed these patches are Gray 35, Gray 50 etc.
So there is nothing to worry about disk accuracy.
post #18 of 27 Old 02-14-15, 05:46 AM Thread Starter
ConnecTED's Avatar
Dear disk users,
There some interesting new measurement options for HCFR users that using Ted’s LightSpace CMS Calibration Disk.
HCFR 3.1.7 (free open source calibration software) has been released and it's adding some extra measurement options for Ted's LightSpace CMS Calibration Disk of Free Version or Full Version users. For full HCFR release notes look here.
Using HCFR 3.1.7 (or later version) with Ted’s LightSpace CMS Calibration Disk Chapters that are available to the CalMAN/ChromaPure sessions of the disk, you can take measurements for the following Color Checker Patterns:
For Ted’s LightSpace CMS Calibration Disk (Free Version) users:
CalMAN’s Color Checker Classic (24 Colors)
For Ted’s LightSpace CMS Calibration Disk (Full Version) users:
CalMAN’s Color Checker SG (96 Colors)
CalMAN’s Color Checker SG Fleshtones (19 Colors)
ChromaPure’s Color Checker (25 Colors)
ChromaPure’s Color Checker Skin Tones (19 Colors)
HCFR 3.1.7 follows the same pattern order with Ted’s LightSpace CMS Calibration Disk Chapters for any of the above measurement options and the HCFR’s 8-bit RGB Triplets for each pattern are matching exactly the RGB Triplets that the Ted’s LightSpace CMS Calibration disk has been encoded.
Below you can find the updated list of the total CalMAN and ChromaPure Chapters that any HCFR user can use to take measurements. These Disk Chapters are accurate and match the HCFR's Color Engine Calculations.
Instructions for x-Point Grayscale Chapters Measurements
Uncheck ''use round down levels" that is located to HCFR ‘’Preferences’’ -> ‘’General’’ Tab. This is affecting only Grayscale measurements.
Instructions for Color Checker Chapters Measurements
Before starting the measurements you have to select from HCFR's Preferences -> ''General'' Tab -> ''Color Checker Patterns'' drop down menu list the selection of the measurement run you want to perform.
Select ‘’GCD’’ if you want to measure using ChromaPure’s Color Checker Chapter.
Select ‘’ChromaPure skin tones’’ if you want to measure using ChromaPure’s Color Checker Skin Tones Chapter.
Select ‘’CalMAN Classic’’ if you want to measure using CalMAN’s Color Checker Classic Chapter.
Select ‘’CalMAN SG’’ if you want to measure using CalMAN’s Color Checker SG Chapter.
Select ‘’CalMAN SG skin tones’’ if you want to measure using CalMAN’s Color Checker SG Flesh Tones Chapter.
Note that there differences between the RGB Targets of CalMAN vs. ChromaPure ColorChecker & Skintones patterns.
Thanks Zoyd (current developer of HCFR) for adding these new features.
post #19 of 27 Old 03-21-15, 05:54 AM Thread Starter
ConnecTED's Avatar
Disk Media Change for Disk Copy of Ted's LightSpace CMS Calibration Disk
Since October 2013 Ted's LightSpace CMS Calibration Disk Versions 1.0/1.1 were using Blu-Ray Disk Media from JVC Taiyo Yuden (for Professional Use) WaterShield - Glossy White Inkjet Printable BD-25GB (LTH Type) Single Layer Disc. (Made In Japan).
That type of disk now has been discontinued by JVC Taiyo Yuden and there is not available any stock anymore.
From now, it will be used the JVC Taiyo Yuden (for Professional Use) - Matt White Inkjet Printable BD-25GB (LTH Type) Single Layer Disc. (Made In Japan).
post #20 of 27 Old 04-02-15, 05:36 AM Thread Starter
ConnecTED's Avatar
DVDO's AVLab TPG 4K Reference Pattern Generator with firmware 01.03.769 has added a very useful feature that is called 'Color Checker'. Using that feature it can provide real-time analysis of digital value for selected pixel from it's HDMI Input.
Professional & Enthusiast calibrators has find this feature very valuable, to check the accuracy of any player output, testing various colorspace output options etc. using Ted's LightSpace CMS Calibration Disk as a reference to detect digital errors that wrong player settings can introduce.
To help them out checking some patterns of my calibration disk, I will start by giving out the 8bit RGB Triplets of some Color Reproductions Patterns to help them reduce the time it will be required for this test.
I will start with the RGB Triplets of the Advanced Black & White Flashing Bars Pattern, others will follow soon.
Here is a small preview of the Advanced Black & White Flashing Bars Pattern with RGB Triplets per color:
Here is a zoomed version:
Because the RGB Triplets are looking very small in a 1920x1080 picture, I have re-designed it at 3840x2160 resolution, you can download it from here: Advanced Black & White Flashing Bars Pattern (2160p)
The issue I has thinking about was how to accurately calculate the dE between two RGB Triplet values, to evaluate any digital error.
I asked from Tom Huffman to help me about this (the creator of ChromaPure Calibration Software) and Tom some hours later came with a Tool that you can download it for free, for dE Analysis.
It's the ''Combination Color Format Converter and ΔE Analysis'' Excel Spreadsheet and you can download it from here.
Thanks Tom for your time providing this free tool so quickly after my request for help, while I know that you are so busy to finish ChromaPure 3.0. Thanks.
calibration , cms , disk , lightspace , ted
