LightSpace DPS (up to 21-Point Cube 9.261 Colors Free Display Check Version) - Page 4 - Home Theater Forum and Systems - HomeTheaterShack.com
post #31 of 58 Old 01-11-17, 05:11 PM Thread Starter
ConnecTED's Avatar
Re: LightSpace DPS (up to 21-Point Cube 9.261 Colors Free Display Check Version)
LightSpace CMS 7.1.7.2516 (10 January 2017) has been released.
As is usual for Light Illusion's continued development process for LightSpace CMS a raft of new developments have been released.
Release Notes
Adjusted Gamut Coverage calculation on LUT Generation.
Changes to support new BoxIO firmware.
Download Link
Software: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
Video Processors: eeColor 3D LUT Box, Darbee DVP-5000 - Pattern Generator: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1Display PRO, Chroma 5 PRO
ConnecTED is offline
post #32 of 58 Old 01-31-17, 05:23 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.7.2523 (29 January 2017) has been released.
Release Notes
Corrected HDR Multiplier reported values for Manual Measure.
Added Eizo CG247X LUT Upload capability.
Fixed ‘Smooth’ LUT Manipulation filter bug introduced in previous release.
Full v1 release of LightSpace Connect.
Auto-connect for Android version of LightSpace Connect.
Download Link
post #33 of 58 Old 02-06-17, 04:23 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.7.2530 (5 February 2017) has been released.
Release Notes
Auto IP address scan for LightSpace Connect.
Simplified the way the ST2084 Multiplier works.
Added direct Osee display patch generation.
Corrected i1Pro2 error with LED introduced in previous update.
Added additional CineSpace LUT format.
Download Link
post #34 of 58 Old 03-14-17, 12:02 PM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.8.2552 (10 March 2017) has been released.
Release Notes
Change to dE calculation for displayed values.
Added Philips/Technicolor HDR standard.
Altered Arri Look XML format.
Added eeColor First 1D LUT format.
Alteration to Eizo display options for CG232W.
Added new AEQKroma display integration.
Drift Compensation patches added to DIP mode and CSV export lists.
Added DICOM medical standard (Beta).
Corrected CS200 name in discoverable probes.
Added ACEScg.
Corrected an error when using Fit/Fix Chroma with BT1886.
Download Link
post #35 of 58 Old 03-20-17, 01:59 PM Thread Starter
ConnecTED's Avatar
LightSpace CMS 7.1.8.2555 (16 March 2017) has been released.
Release Notes
Added EclairColor HDR colour space standard.
Added ACEScc and ACESproxy.
Fixed a bug with saving new colour spaces introduced in last build.
Download Link
post #36 of 58 Old 04-04-17, 02:39 AM Thread Starter
ConnecTED's Avatar
Steve's Shaw Interview @ British Cinematographer (March 2017) with a lot of it's background info, here.
post #37 of 58 Old 04-20-17, 01:26 PM Thread Starter
ConnecTED's Avatar
LightSpace CMS 8.0.0.2570 (19 April 2017) has been released.
Release Notes
Fixed crash with ST2084 Multiplier introduced in last build.
Added Camera colour spaces for LUT generation - PRO and XPT (Beta).
Added 'Null' colour space.
Fixed Crash with Drift of 1.
Change to Java App XML management to improve stability.
Added Drift Function with imported CSV sequences.
Download Link
post #38 of 58 Old 06-05-17, 07:44 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 8.0.0.2591 (02 June 2017) has been released.
Release Notes
Fixed BT1886 not saving as new User colour space.
Add Tone Mapping and Push/Pull Exposure (Stops) to Camera option.
Fixed issue with ‘Drift’ options not always showing in Convert Colour Space.
Added new LUT formats.
Linked sliders when using numeric text entry.
Changed Tab operation to step between slider numeric boxes.
Removed unnecessary extra delay on Network Manager.
Added initial idea for APL patch control.
Altered Drift Patch operation for .csv files – now works logically.
Changes to Network Manager for Patch size/position/bg colour (Beta).
Download Link
Note: All LightSpace related guides which are available online has been updated to reflect changes the latest released version of LightSpace introduced.
post #39 of 58 Old 06-13-17, 08:41 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 8.0.0.2603 (12 June 2017) has been released.
Release Notes
Added further ‘Camera Options’ for LUT generation.
Added ACES/Autodesk CLF/CTF LUT Format Import/Export.
Changes to Network Manager for Patch size/position/bg colour (very Beta, and not correct!).
Additional changes listed in the associated 'Changes' document.
Download Link
post #40 of 58 Old 07-05-17, 06:12 PM Thread Starter
ConnecTED's Avatar
LightSpace CMS 8.0.0.2621 (4 July 2017) has been released.
Release Notes
Changed the display of Target/Actual data during Quick Profile so they 'Sync'.
Improved stability of Java App patch generator.
Enabled full-screen removal of borders on Java App patch window with double click.
Added User Patches via .csv file and dpx frames to Quick Profiles.
Corrected Arri Gamut calculation in Camera Options.
Corrected display of measured values in Manual Measure mode with Active LUT.
Change to SIX-G patch scaling.
Download Link
21point , check , colors , cube , display , dps , free , lightspace , version
