LightSpace DPS (up to 21-Point Cube 9.261 Colors Free Display Check Version) - Page 6 - Home Theater Forum and Systems - HomeTheaterShack.com
post #51 of 58 Old 02-10-18, 02:46 PM Thread Starter
ConnecTED's Avatar
Re: LightSpace DPS (up to 21-Point Cube 9.261 Colors Free Display Check Version)
LightSpace CMS 9.0.0.2772 (10 February 2018) has been released, its the biggest even change to LightSpace CMS!
Light Illusion is delighted to announce a totally new development of the LightSpace CMS advanced Colour Engine, which is at the heart of the unparalleled calibration accuracy of LightSpace CMS.
In excess of 11 man-months of development work has gone into a total rewrite and enhancement of the advanced algorithms and mathematics that are at the core of the LightSpace Colour Engine, with visible and measurable improvements in all final calibration results.
Although the existing 2nd Generation Colour Engine has already proven to be more accurate, as well as faster, than any alternative calibration system, nothing is ever perfect, and we knew we could do better. And the new Gen3 Colour Engine does just that, enhancing every aspect of LightSpace based calibration.
Extensive Beta Testing has shown significant benefit across the board, with improved grey-scale tracking, better control of blacks & shadows, greater accuracy for skin tones and other memory colours, with greatly reduced Delta-E values overall.
The following graphs show the existing Gen2 Colour Engine vs. the new Gen3. The improved calibration is easy to see, with less random/noisy CIE plots, and greatly improved dE distribution.
Note: This is an OLED display calibrated with an i1D3 probe. For clarity those point below the probe's minimum brightness threshold have been removed from the CIE plots, but are included in the dE Distribution graphs.
With the Gen3 Colour Engine the total volumetric accuracy of any calibration has been greatly improved!
Release Notes
New 3rd Gen. Colour Engine greatly increasing calibration accuracy.
Added initial support for Eizo Prominence CG3145.
Edit Profile Points in pop-up window.
Add new graphs to PDF reports.
Added Super White option for VideoScale.
Improved probe switching and connecting operation.
Added a catch for patch read value with zero Z or negative value (XYZ).
Download Link
Note: All LightSpace related guides which are available online has been updated to reflect changes the latest released version of LightSpace introduced.
All new features and developments are provided free to existing customers, continuing Light Illusion's approach of no additional costs or yearly support fees for all its software systems.
Software: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
Video Processors: eeColor 3D LUT Box, Darbee DVP-5000 - Pattern Generator: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1Display PRO, Chroma 5 PRO
ConnecTED is offline
post #52 of 58 Old 02-17-18, 02:27 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 9.0.0.2776 (15 February 2018) has been released.
As is usual for Light Illusion's continued development process for LightSpace CMS a raft of new developments have been released.
9.0.0.2776 Incremental Release Notes
Added support for IS-miniX.
Fixed PDF report graphdata selection inaccuracies.
Increased PDF Report Min Luma value to 4 decimal places.
Full 9.0.0 Release Notes
Fixed issue with some Eizo displays internal TPG not connecting to LightSpace.
Added workaround for Eizo SDK issue with newer models (e.g. CG247X).
Sort Profile Points in logical order in pop-up window.
Correct use of 'Active LUT' with some internal LightSpace options.
Added Lilliput LUT Formats.
Corrected NEC Gen1 chassis connection issue.
Updated Konvision Upload menu options.
Replace Discus DLL with new version.
Corrected possible issue with Min/Max reporting via Luma Thermometer.
Add fix for Accupel bug (since fixed by Accupel too).
Updated Jeti DLL.
Fixed potential crash with CR probes.
Added a catch for patch read value with zero Z or negative value (XYZ) (Due to invalid probe readings).
Change to Licensing to reduce lockout due to OS updates. (Will require a license re-set by Light Illusion, so plan that into any update schedule!)
Download Link
post #53 of 58 Old 02-20-18, 03:47 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 9.0.0.2777 (19 February 2018) has been released.
Release Notes
Corrected Patch Scale function when used with display profile.
Download Link
post #54 of 58 Old 03-19-18, 07:35 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 9.0.0.2783 (13 March 2018), an incremental version, has been released.
Release Notes
Added ICtCp dE reporting for HDR and SDR.
Fixed Patch Scaling error for Network Manager BG colours.
Adjusted PDF Report dE reporting for very low values.
Updated IS-mini SDK to fix WOWOW bug.
Added initial concept of ‘Sub Colour Space’ for Quick Profile verification.
Adjusted Eizo ‘Standard’ LUT calibration to prevent banding
has been released.
Download Link
post #55 of 58 Old 03-28-18, 05:26 AM Thread Starter
ConnecTED's Avatar
LightSpace Beta with Patch Stabilisation Insertion feature.
To fight drifting, the LightSpace had 2 features which are working very good; Drift Compensation and Anisometric patch sequence which both of them helps to final 3D LUT correction generation for better final results.
Using Drift Compensation feature enabled with 30 value for example, LightSpace it takes a one White measurement per 30 patches and at the end it's including to the correction 3D LUT any display 'drifting over the time' issues, we have seen that OLED's/Plasma's are not stable displays during the required measuring time and this features helps a lot to the final 3D LUT generation.
Anisometric patch sequence is helping a lot also and it's better suited to displays that have any form of ABL, such as Plasmas and many OLEDs, where Sequential patch ordering can cause display overheating (overheating can actually be an issue on any display that has high peak luminance outputs, as it can cause the display to drift. Anisometric patch sequence is using an algorithm to display the patches with one dark/one bright patch order in simple words.
We have seen with Plasmas that luminance drop because when the panel or electronics increase their temperature (or PSU overload), the display has sensors to panel and electronics area to monitor these changes, so to protect the panel/electronics, it's reducing the output to protect and prevent any damage.
With OLED's there strange shiftings and weird luminance changes from thermal changes to the pixels of the pattern area so to help the panel cool down there is added a Patch Stabilisation Insertion feature.
The Stabilisation feature you can find it to the 'Options' menu.
The main idea is to add black frames displayed for x.xx sec. time between each other colorpatch (for example 200ms of black patch) but there capability to select any color (any RGB triplet) and decide exact the time you want for these patches to be displayed in milliseconds. After testing we will find out which patch insertion is better, a black frame or a dark gray one...or which timing provides better results etc.
These 'Stabilisation' patches are presently only with 'profiling'; but to the official release there will be available to 'Manual Measure', for LightSpace DPS (free license level) users to be able to use them also.
For a download link of this Beta. please send me msg here only: http://www.displaycalibrations.com/contact_us.html
post #56 of 58 Old 03-28-18, 04:27 PM Thread Starter
ConnecTED's Avatar
There available newer beta which adds 'Stabilization' to Manual Measure, something which LightSpace DPS (free licence levels) users can use.
There added details about the Stabilisation to the LightSpace on-line manual also: https://www.lightillusion.com/profiling_manual.html
post #57 of 58 Old 04-25-18, 03:45 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 9.0.0.2802 (24 April 2018) has been released.
Release Notes
Added ‘Stabilisation’ option for displays with ABL/Heat type issues.
Continuation of Sub Colour Space developments.
Changed Accupel 5000 integration allow faster patch generation.
Fixed potential COMs issue with hardware TPGs after using the ‘Options’ menu.
Added integration for Minolta CA-410 probe.
Added pop-up window to see additional dE information without exporting pdf report.
Finalized BenQ 3D LUT integration.
Download Link: https://www.lightillusion.com/downloads.html
post #58 of 58 Old 05-31-18, 10:18 AM Thread Starter
ConnecTED's Avatar
LightSpace CMS 9.0.0.2816 (31 May 2018) has been released.
Release Notes
Altered Anisometric sequence for display thermal/colour memory issues.
Added Pre-roll capability, to pre-warm display and probe before profiling.
Added DJI Cameras to Camera Options (excluding 3200 ISO).
21point , check , colors , cube , display , dps , free , lightspace , version
