5.1 - Home Theater Forum and Systems - HomeTheaterShack.com
post #1 of 5 Old 10-07-11, 01:20 AM Thread Starter
5.1
I have Bose 5.1 with a yamaha receiver, xbox 360 gets 5.1 audio but ps3 stays as PCM, I'm using the same optical cable on both machines. Any ideas?
pilotdreams is offline
post #2 of 5 Old 10-07-11, 01:57 AM
Ares's Avatar
Tony
Re: 5.1
Have you gone to the Audio Settings of the PS3? When you set it up for audio output via the optical it will give you the following options DD 5.1, DTS 5.1, PCM 2 Ch 44.1kHz, PCM 2 CH 48.1kHz, PCM 2 Ch 88.2kHz and PCM 2 Ch 176.4kHz check all of the the ones that your receiver is able handle.
Do not go where the path may lead, go instead where there is no path and leave a trail. -Ralph Waldo Emerson
Ares is offline
post #3 of 5 Old 10-08-11, 01:29 PM Thread Starter
I did, 44 and 48khz are permanently selected aswell as everything else except the higher kHz range.
post #4 of 5 Old 10-10-11, 03:20 AM
Ares's Avatar
Tony
Re: 5.1
If the problem happens during BD playback as well go into the Video Settings and change it from PCM to either Bitstream (Direct) or Bitstream (Mix).
Bitstream (Direct) Set to output audio with the original digital signal prioritized.
Bitstream (Mix) Set to output audio that has been mixed with sound effects such as button sounds and then converted to bitstream format.
Hints
  • If [Bitstream (Direct)] is selected, some portions of the audio content may not be output.
  • If [Bitstream (Mix)] is selected, audio will be output in Bitstream (Direct) while Blu-ray 3Dô content is being played.
Ares is offline
post #5 of 5 Old 10-11-11, 12:52 AM Thread Starter
Looks like I've got it figured out. It automatically switches to the best sound program except when listening to music, have to change it from neo 6 to 7ch speaker for full sound.
51
