1 - 4 of 4 Posts
not sure where to post this so i apologize in advance if its in the wrong spot.
I have an epson 8350 and I play blurays on my pioneer bluray player that the bluray box says is a
1080p bluray. however when I view the "info" window from "menu" on the epson 8350 it will show the input as 1080i. what gives? why doesnt it show it as 1080p?
dont get me wrong the quality of the picture is fantastic I am just wondering what is going on. thks bob
Discussion Starter · #4 · (Edited)
luckily i had my spare owners manual copy at work for this very type of emergency situation....i see where i can go to a "setup" menu and and control HDMI Out resolution. my choices are auto,480i,480p,720p,1080i,1080p. it seems like i should choose auto since i do play regular old dvds also.
I do not understand this though.....for the 480i through 1080p selections it has this caveat "output the video signals from the HDMI OUT terminal with the selected resolution, the resolution can be changed by pressing HDMI but AUTO cannot be selected"
what does it mean AUTO cannot be selected? maybe it means i cant select both at the same time but thats pretty self explanatory am I missing something?
edit: did some more digging looks like the initial set up menu controls the resolution for the "TV" output ....time to go home and play around with it
1 - 4 of 4 Posts
