Hi all,
I've built a couple of pairs of speakers before (floorstanders & bookshelves), and have decided it time to tackle the sub that they both want/need.
I want fairly tight and accurate bass for music and HT is secondary, so i've decided a sealed sub should do the trick. I'm building a modular hifi cabinet and the sub will just be an extra box, so the volume is limited to about 2.2 cubic feet.
I am down to the Dayton RSS315HF-4 or the slightly less well known CSS SD12, with a 300W Oaudio bash amp.
From what i've read the oaudio and PE bash amps are really similar, though the oaudio are by default better suited to sealed arrangement because of the (was it 30hz?) boost. and I think the caps on the inside are slightly bigger, though i've got no idea what that means.
It's quite hard to find details on the CSS driver.
