1 - 8 of 8 Posts
Hello
I am thinking I might be better off with dual subs rather than one big one with a 3 LMSRs.
SO the question is what size sonotube would i Need to run my 12" LMSRs. Thinking of building 2 ported.
Any help is greatly appreactiated.
Doug
Super Moderator
Are these for home theater?
If so you could use a 17" wide tube. But it all depends on how low you want to tune for and your space restrictions.
Discussion Starter #6
HI Mike
How will it perform best. If I go with a small box with 1 or 2 prs what can I get out of it. I will put as much power to it as needed.
Doing the 3 I was orginally going to with the Hex box. Just is to complicated of a build for me and box building cost estimates I have gotten are 750-1K. I can do a normal box myself not so complicated.
Super Moderator
Hex would be a cool design and it would not be that difficult to build. Just the angle cuts is all. But either way you could do a single box/pr's or buy another 12" and do dual 12's and 4pr's per cabinet or have three cabinets placed in completely different locations for better overall bass response.
Many options still out there.
1 - 8 of 8 Posts
