1 - 4 of 4 Posts
I want to be able to power on my DIY power amp via the 12v control on my Yamaha CXA5100 preamp...does anyone know of a device i could plug into a outlet, and the plug the amp into it that would turn the amp on and off?
I have Insteon outdoor outlets, but they control via the powerline.
Discussion Starter #2
Discussion Starter #4
I’m assuming something like Panamax won’t do what you need?
No... I need individual units for each channel, as the speakers will be all around the room. I might have a solution though since i have Insteon outlets. The solution is to use iRule or another home automation program for control. Then I could layer the outlets into the commands, and even turn on and off amps according to needs...like only 2 amps for stereo, and all for surround modes. :)
1 - 4 of 4 Posts
