I'm wanting to put together an easy-to-construct sub that's efficient on dB/$ with some sense of quality.
A reasonable size is also desirable. To pull it off I'm hoping to put the most efficient big sub in the smallest large box I can muster, rather than a high power small sub... hence the dB/$ goal.
Right now what I have put together is a prefab 3.0cuft box, the new version of the 15" Dayton Classic Sub (DCS385-4), in a vented alignment tuned to 24Hz with a cheap 4"x17" port kit (air velocity doesn't break 20m/s). Powered with a 300W Bash amp, xmax isn't breached until <17Hz. The total comes to about $425.
Comments on the build or suggestions for similar price and performance? This sub will be integrated into my system, the mains are 3cuft w/ 12-inchers.
I've considered a sealed sub but for a good Qtc I'd have to go with a much smaller sub and lose out on a lot of output (this 15 in the same box has a high Qtc of 0.9+). A big point to limit cost was to stay on the 240W or 300W power range. The 3.0cuft sized box is about as big as I can really go since I'm trying to avoid building one or having a box built for this project. The goal being to have this sub for a couple years until I can go all out on a "real" sub ;-)
EDIT: final specs are 3cuft, 4"x24" round port tuned @ 21Hz w/ Dayton QT385-4 & 300W Bash amp. EQ'd via computer with +2db @ 20Hz and +2dB @ 31Hz.
w/ LPF @ 60Hz
w/ LPF @ 60Hz
