Well you've made a good start Jack, with a 2.4:1 screen..:T
More and more people are going this route now for their standard 16:9 projection..
It does make life a bit easier with just side masking for 16:9, or not bothering with it at all..
I've never found the need to mask my 2.4:1 screen..
However, you are missing out on full image quality, when you zoom to fill the screen..The pixels are being stretched horizontally and vertically, which degrades the image to some degree..
To give you an idea of how much better it would look, when you use an anamorphic lens..
Next time you have a 2.35:1 movie up on the screen, take a close look at how sharp and detailed it is, prior to zooming..
This is almost the same detail you will see, when a lens is used to expand the image..
If you go the DIY way or buy a lens kit assembly, it's not all that expensive to have a very reasonable anamorphic lens..
